Old 09-05-2008, 19:47   #1 (permalink)
muttley
muttley's Avatar
electrical cut out
Ok I have a little problem,
I have keyless ignition, push button starter.
I have an electrical cut out to the battery, when this is isolated the engine continues to run ???
what wire do i need to add to the electrical cut out to stop the engine ?
muttley is offline   Reply With Quote
Old 09-05-2008, 19:49   #2 (permalink)
initial_j
has issues..
initial_j's Avatar
is it just a switch in the battery positive wire? as if so then it will continue to run, you need to wire it also to the ignition wires by the key barrel if that makes sense
Old 09-05-2008, 19:51   #3 (permalink)
Andy_f
Quad tone.
Andy_f's Avatar
Or you can cut the power to the ECU, or you can cut the feed from the alternator.
Old 09-05-2008, 20:06   #4 (permalink)
muttley
muttley's Avatar
there is no key barrel, and I have tried to disconnect the main wire to key barrel wiring, but still the engine runs..
Old 09-05-2008, 21:04   #5 (permalink)
gaz_moose
whats my name
cut into the wire for the eccs relay
