Old 11-05-2008, 00:00   #1 (permalink)
jimmy crowley
jimmy crowley's Avatar
##**engine spec check up****(urgent)
just wonderin how this sounhds lads its a 180 i have the option of doing a deal with the hachi.what do you think of the spec is it all legit??345 bhp supposedly??S15 engine/turbo + New Hks head gasket,Upgraded cams,Hks manifold,Full 4' exhuast turbo back,Hks Induction,Hks F-con Ecu +upgrade injectors,Hks plugs+upgraded leads,Upgraded fuel pump+Sard Fuel pres reg,Nismo clutch+lightend flywheel,Nismo 2-way diff,Zeal Coilovers,Greedy front strut brace,Nismo rear arms,Short shift gearbox,Alloy Radiator,Fmic,Oil catch can
183.photobucket.com/albums/x196/murray555/101_0190.jpg
jimmy crowley is offline   Reply With Quote
Old 11-05-2008, 00:42   #2 (permalink)
SteveC200
talent bypass
SteveC200's Avatar
I'm doubtful it would make that power on a stock S15 turbo.
Old 11-05-2008, 00:47   #3 (permalink)
pizzaboy
splendiferous
pizzaboy's Avatar
Yup as mentioned 345bhp is beyond the stock turbo capability. Ask the seller where he got the figure from.
pizzaboy is offline   Reply With Quote
Old 11-05-2008, 00:48   #4 (permalink)
RyanH
Is it really beyond the stock turbo? thought they could run like 1.6 bar?
I got 310bhp at 1.2 bar...
RyanH is offline   Reply With Quote
Old 11-05-2008, 00:55   #5 (permalink)
jimmy crowley
it came from japan like this the last owener recond it was this power .what ya think of the engine spec how does it sound for a daily driver/drifter??thers also different coil packs
Old 11-05-2008, 01:27   #6 (permalink)
nissansilvia
well japs are crazy and they can pretty much do things that beyond our imagination!!!
and 345 isn't all that crazy. if its tuned and mapped really really well!!!which jap are good at doin so!
nissansilvia is offline   Reply With Quote
Old 11-05-2008, 01:31   #7 (permalink)
pizzaboy
splendiferous
pizzaboy's Avatar
Yes but theres diminishing returns after that. Highest I've seen on sxoc, running the stock unit to poopy point, was 320-325bhp odd. It could be he has a gt2871 or similar but just doesn't realise it. If it is 345bhp it's deffo the highest I've seen by a good margin.
Old 11-05-2008, 01:35   #8 (permalink)
initial_j
has issues..
initial_j's Avatar
you could turn it up to 1.6bar itd probably last a week or two! 345bhp from that spec is unlikely, unless its running a big turbo. i ran my gt28rs @1.4bar and that wasnt far from its limits
Old 11-05-2008, 01:46   #9 (permalink)
jimmy crowley
see the pic in the thread whats the story with the afm if there is just that pipe straight from the filter to the turbo??
Old 11-05-2008, 02:27   #10 (permalink)
nissansilvia
prop running wide band and binned the afm!!!much better!!!
Old 11-05-2008, 06:52   #11 (permalink)
SteveC200
talent bypass
SteveC200's Avatar
Sorry? Hes running a wide band what? Lambda sensor? Totally unrelated to air flow measurement. The ECU is probably using a MAP sensor so the AFM isnt needed.
As for the car, I have a sneaking suspicion that the car wont have a stock turbo considering the rest of the engine spec as it would seem a bit of an odd tuning route to upgrade all the other parts, which are quite expensive, but not the turbo.
Old 11-05-2008, 10:23   #12 (permalink)
jimmy crowley
good car, worth getting????
Old 11-05-2008, 10:38   #13 (permalink)
manfoot
TEAM GREEN
manfoot's Avatar
the hks ecus dont use afm they use a map sensor
manfoot is offline   Reply With Quote
Old 12-05-2008, 00:46   #14 (permalink)
Nissanboy
_________
no way is that running a stock turbo, would like to see it when it arrives as it seems very nice spec. My bet is go for it if the money is right.
Nissanboy is offline   Reply With Quote
Old 13-05-2008, 02:30   #15 (permalink)
jimmy crowley
got the car its absolute animal power peak boost is around .72 .it goes to 100k in around 3.5 seconds according to my friend in the passenger seat.wil spin in third gear in the dry few theeting problems already do unfortunatly (see other thread help needed)
