12-05-2008, 10:33
| gripper Join Date: May 2008
| expected power? s13 hi all i am looking to but my first drift car what kind of power could i expect from the following spec and do you think it would handle ok? ca18det Rebuilt T25, 360deg thrust bearings Forge actuator Braided turbo lines 3" downpipe and straight through system induction kit uprated oil and radiator caps boost gauge Denso iridium plugs Tein SS coilovers Veilside rear strut brace Stripped rear 16x8 Rota Grid Drift Cheers |
12-05-2008, 10:41
| #3 (permalink) |
| S1- F.T break! Join Date: Nov 2005
| ca18det --- 160bhp Rebuilt T25, 360deg thrust bearings --- plus 40 bhp Forge actuator --- plus 33bhp Braided turbo lines ---- plus 56.345 bhp 3" downpipe and straight through system --- plus 32 bhp induction kit ---- plus 73.2 bhp uprated oil and radiator caps --- plus 592bhp boost gauge --- plus 78bhp Denso iridium plugs --- plus 23bhp Tein SS coilovers - plus 10 handling points Veilside rear strut brace --- plus 33 handling points and 75 bhp Stripped rear --- plus 15 handling points and 8.3 bhp 16x8 Rota Grid Drift -- plus 4 handling points (more for stretchu) and 2bhp I make that at 639.845 bhp and 62 handling points. I reckon you could get about 20bhp extra if you ran the oil cap at a higher pressure though. Handling should be good so you'll be a driving god in a couple of days as well ![]() |
12-05-2008, 10:53
| #5 (permalink) | |
| TeamLifestyler Join Date: Apr 2007 Location: Sussex
For 250? Do a search on here... For Stage 2 set ups.. That tends to end up at about 280ish... You'll want a FMIC of some sort, more boost, and a chip | |
12-05-2008, 12:39
| #13 (permalink) |
| You don't need loads of power to drift mate. 9/10 people reckon its much better to learn on a low power car as well, because of the way you have to really learn the techniques to make it work. It will drift perfectly fine as it is. |
12-05-2008, 13:31
| #15 (permalink) |
| blacksmith | dont spend moneys on a ca18 because it will all be waisted cos they are crapola ,just spend money on tires ,drify wheels and practice days you WILL have much more fun , then when once you have got pissed iff with changing ca18's put a sr20 in (waits for bizzle to see this and start a sr20 vs ca18 war again ) |
12-05-2008, 14:12
| #16 (permalink) | |
| dorifto kingu! ![]() Join Date: Aug 2004
![]() Jeeeesus, you would have thought after Doc vs Bizzle round one you might have actually noticed that they arent, but what the hell. ![]() The winner of time attack clubman last year had a CA, the most powerful 200SX in the UK (probably Europe) has one, various EDC drivers have and still are competing with them blah blah blah. If looked after they are as reliable as anything else. ![]() | |
14-05-2008, 12:05
| #17 (permalink) | |
| blacksmith | Quote:
