Old 12-05-2008, 23:02   #1 (permalink)
jimmy crowley
jimmy crowley's Avatar
help needed asap 180 sx s15 engine
got the 180 was drivin in the road and it slowed up and stopped no fuel pump noise but wil fire (not start) any suggestions???
jimmy crowley is offline   Reply With Quote
Old 12-05-2008, 23:58   #2 (permalink)
nissansilvia
isnt that like a fuels of the pump or the pump is dead?
nissansilvia is offline   Reply With Quote
Old 12-05-2008, 23:59   #3 (permalink)
nissansilvia
i meant fuse
Old 13-05-2008, 00:31   #4 (permalink)
jimmy crowley
checked the fuses theres power to the fuse in the engine bay but none at the pump..how does the pump know when to cut off??
Old 13-05-2008, 01:02   #5 (permalink)
suprmek1
Dori Mechanic
suprmek1's Avatar
Broken wire or pump controler on the ecu
Old 13-05-2008, 01:28   #6 (permalink)
jimmy crowley
what is the pump controller how do i solve it ??theres a piggy back system on it i think.it has ports on the front for a laptop looks like f.con or something please be a broken wire.did u hear of a broken wire before?
Old 13-05-2008, 02:40   #7 (permalink)
jimmy crowley
help??
Old 13-05-2008, 11:09   #8 (permalink)
jimmy crowley
could this be anything to do with the ecu??bee-r??or turbo timer or boost controller or ignition switch any help
Old 13-05-2008, 12:19   #9 (permalink)
jimmy crowley
this is my daily driver lads help a brother out!!
Old 13-05-2008, 13:21   #10 (permalink)
andy bird
why not take a wire to the pump direct from the battery maybe fused and see if it will run like that
that will see if the pump is shagged or not apart from that you would need to check wiring and the ecu
andy bird is offline   Reply With Quote
Old 13-05-2008, 15:39   #11 (permalink)
jimmy crowley
wire not soldered propper on pump walboro..
Old 13-05-2008, 15:44   #12 (permalink)
andy bird
fixed then
Old 13-05-2008, 16:25   #13 (permalink)
jimmy crowley
yep case closed
