Old 12-05-2008, 23:16   #1 (permalink)
Evan s13
Evan s13's Avatar
ca18det temp fluctuating ?? help ??
I went out in the car tonight and it was fine for a couple of hours then on the way back the temp wen t up to the red then came back down again it did this several times then stayed on the red so pulled over then the steam started coming out of the header tank the only thing is if i press on the rad cap it stops bubbling out of the header tank, i have taken the thermostat out and still the same also tryed my mates rad cap and still the same ??
HELP PLEASE
Evan s13 is offline   Reply With Quote
Old 13-05-2008, 01:04   #2 (permalink)
suprmek1
Dori Mechanic
suprmek1's Avatar
Possible air lock needs bleading
Old 13-05-2008, 07:05   #3 (permalink)
SteveC200
talent bypass
SteveC200's Avatar
Air lock or blocked rad at a guess.
Old 13-05-2008, 13:32   #4 (permalink)
Pikey
Pikey's Avatar
Put up with it or get a bigger radiator.
Old 13-05-2008, 16:41   #5 (permalink)
Evan s13
Evan s13's Avatar
is this common on a ca18det
Old 13-05-2008, 18:26   #6 (permalink)
SteveC200
talent bypass
SteveC200's Avatar
Only if youve got a blocked rad or an air lock.
Old 13-05-2008, 18:29   #7 (permalink)
docwra
docwra's Avatar
There is another explanation but I dont want to scare you.
Two Q's:
Do the heaters work? What about when the temp goes in the red?
If you drive the car TOTALLY off boost, do you get the same problem?
docwra is offline   Reply With Quote
Old 14-05-2008, 00:36   #8 (permalink)
Evan s13
Evan s13's Avatar
yer it will happen at random times if you drive under boost it still does it the only other thing i can think off is i have a fmic could this be blocking air getting to the rad also the heaters work when on red but will go cold when it drops
thanks
Old 14-05-2008, 06:00   #9 (permalink)
SteveC200
talent bypass
SteveC200's Avatar
Wont be the fmic. I reckon airlock.
Old 16-05-2008, 23:17   #10 (permalink)
Evan s13
Evan s13's Avatar
docwra you were right head gasket gone today big time only changed 350 miles ago i think i was supplyed with the wrong gasket apparently there is 2.
