Old 13-05-2008, 16:05   #1 (permalink)
RyanS13
RyanS13's Avatar
Failed Emissions JZX100
I had just had my MK11 JZX100 in for it's mot and it failed the emission test miserably on everything . Does anyone have an idea what i could do to fix it. It does have a cat on it. Could it have anything to do with it being mapped for 100 ron fuel?
Required, My Reading
CO 0.300, 9.215
HC 200, 515
Lambda 0.970-1.030, 0.750
RyanS13 is offline   Reply With Quote
Old 13-05-2008, 16:07   #2 (permalink)
cookwibble
cookwibble's Avatar
find a nice friendly mot tester??
Old 13-05-2008, 16:08   #3 (permalink)
RyanS13
RyanS13's Avatar
Tried that with my S14 but there's none around here unfortunately
Old 13-05-2008, 16:40   #4 (permalink)
cookwibble
cookwibble's Avatar
you are gonna struggle i think, my car (jzx90) only just passed the non cat test with the cat still in
Old 13-05-2008, 16:43   #5 (permalink)
RyanS13
RyanS13's Avatar
Is it possible to lower the emissions using my power fc?
Old 13-05-2008, 16:46   #6 (permalink)
cookwibble
cookwibble's Avatar
possible i guess. but you are soooooo far out i dont think it can be done. i dont condone it but some MOT testers offer deluxe MOT tests for £20-£30 more than the standard test nudge nudge wink wink etc.
Old 13-05-2008, 16:49   #7 (permalink)
Stavros
DEYTUKURJURBS
Stavros's Avatar
You could do it with the PFC, running it properly mentally lean etc.
But thats a ballache, friendly MOT testers rock, my JZX81 gives you cancer from just looking at the tailpipe, never mint passing emissions.
Old 13-05-2008, 16:59   #8 (permalink)
Jord
F*ck your EGO.
Jord's Avatar
I've never had either of my Silvias tested for emissions because there isn't a benchmark test for that model.
Old 13-05-2008, 17:04   #9 (permalink)
RyanS13
RyanS13's Avatar
Yeah think i will have to see if i can find a friendly mot tester who would let me accidentally drop a nice £20 note into his pocket
Old 13-05-2008, 17:05   #10 (permalink)
cookwibble
cookwibble's Avatar
what age? if you have a picky mot tester and the car is pre 97 you need to pass a non cat test, if post there is a standardised limit thingy, regardless of benchmarks.
Old 13-05-2008, 17:43   #11 (permalink)
Stavros
DEYTUKURJURBS
Stavros's Avatar
Thought it was 2.5% or 3.5% CO (i forget) non-cat regardless unless mentally old?
Old 13-05-2008, 18:28   #12 (permalink)
turbomalv
turbomalv's Avatar
i am a very friendly mot tester any good to you am in worcester.
turbomalv is offline   Reply With Quote
Old 13-05-2008, 18:46   #13 (permalink)
Seth
Seth's Avatar
My '94 Chaser's just passed the MOT and it hasn't got a cat, the computer didn't know what it was so it just went through on the non-cat test.
I'd suspect the lamda's or something else is faulty if the emissions are that bad
Seth is offline   Reply With Quote
Old 13-05-2008, 19:55   #14 (permalink)
RyanS13
RyanS13's Avatar
Afraid not mate i'm up beside Aberdeen
Old 13-05-2008, 19:59   #15 (permalink)
RyanS13
RyanS13's Avatar
It's a 97 i've got. There is a bit of white smoke coming out the exhaust and i've just had the turbo rebuilt but can't run it in till i get it mot'd and registered
Old 13-05-2008, 22:48   #16 (permalink)
Storm Chaser
Send a message via MSN to Storm Chaser
I went through the same as you did, all hopes including thrashing the crap out of the car for 20 minutes did jack, it meant another trip to Essex for TDi to put on a wide band lambda on it
Storm Chaser is offline   Reply With Quote
Old 13-05-2008, 22:51   #17 (permalink)
Phil
7JZGTE
Phil's Avatar
My 100 had the cat in the original downpipe, and a stainless system after that. It failed it's emissions too.
Phil is offline   Reply With Quote
Old 13-05-2008, 23:24   #18 (permalink)
RyanS13
RyanS13's Avatar
Phil how did you manage to get it to pass?
Old 14-05-2008, 07:08   #19 (permalink)
e30 of Death
Is Lochgelly, fife, too far from you? Might have a suitable MOT tester that way if you contact Chizfab...
My cars would probably pass anyway with them being ancient and non-turbo, but I havn't had any cars emission tested for years
Old 14-05-2008, 07:17   #20 (permalink)
ant
R32 GTR-S
ant's Avatar
Send a message via ICQ to ant
the e30 did actually passs with that engine in it mike, proper test aswell shame the rest of the car failed
ant is offline   Reply With Quote
