Old 13-06-2008, 21:06   #1 (permalink)
matt22robbins
matt22robbins's Avatar
S14 running problems - over fueling and stuttering/spluttering between 3000-5500rpm
Hi guys,
anybody in the westmidlands about this weekend to lend a hand and take a look at my ride.
mods so far to engine are
FMIC, HKS EVC, straight thru exhaust, de cat, air filter, norris design fast road engine,
suddenly devloped this issue where i can smell fuel inside the car, its using a lot more than usual, im now getting 8-10 mpg and when driving between 3000-5500rpm i get this stuttering/spluttering thru the system
ive no idea whats wrong but need to get it fixed before i can consider getting it remapped.
also has anyone any suggestions for next level of mods, got up to £2000 to spend.
if you can offer help can always give me a call on 07920853579 saturday / sunday if ive not responded to pm's as i dont have a pc at home.
cheers
matt
matt22robbins is offline   Reply With Quote
Old 13-06-2008, 21:12   #2 (permalink)
jon1200
Send a message via MSN to jon1200
Could it be you oxygen sensor?
jon1200 is offline   Reply With Quote
Old 13-06-2008, 21:37   #3 (permalink)
islander
gone wrong
Send a message via MSN to islander Send a message via Yahoo to islander
try you fuel tank for leaks, pressure looses in the hoses `so maybe causing fuel cut?
islander is offline   Reply With Quote
Old 15-06-2008, 15:45   #4 (permalink)
steve_fctuning
def sounds like some kinda fuel leak, especially if you can actually smell the fuel mate.
check injector o-ring seals, may be worn? have you ever had any of the fuel pipes off before? perhaps maybe by the fuel filter, if there not clamped back tight or fresh clips used then sometimes, and I say sometimes, they can weep slightly and as it evaporates quickly it can sometimes make it hard to see but when driving and the engine and fuel system is more pressurised underload you can then notice the leak more.
look carefully dude.
Old 15-06-2008, 15:54   #5 (permalink)
Mattias
Send a message via MSN to Mattias
major boost leak?
Mattias is offline   Reply With Quote
Old 15-06-2008, 15:55   #6 (permalink)
steve_fctuning
mm yeah. good point, is the car loosing alot of power? you got a guage plumbed in?
Old 26-06-2008, 16:16   #7 (permalink)
matt22robbins
Cool
Hi guys,
no i dont have a gauge plumbed in have replaced the exhaust manifold as i found a crack in that, but the problem is still there. Will check the fuel, injectors, etc for leaks this weekend and see if i find anything then
cheers
Matt
Old 26-06-2008, 17:08   #8 (permalink)
BanjoMaster
BanjoMaster's Avatar
Most likely your lambda sensor. That's what was wrong with mine.
BanjoMaster is offline   Reply With Quote
Old 27-06-2008, 17:04   #9 (permalink)
steve_fctuning
you sorted out the possible fuel leak mate? you checked around the fuel pipes going into the rail, when they pressure up they expand. Maybe one has a slight split in it, especially if you actually SMELLING fuel.
