Old 19-06-2008, 18:03   #1 (permalink)
s12 silvia
s12 silvia's Avatar
supra auto to manual costs?
hi i can get a supra tt import for good money and i have always fancyd one but its a auto, how much will it cost for everything i need to go manual and how hard is it to convert? also any advise welcom as i have never converted a car before.
regardes
Matt
s12 silvia is offline   Reply With Quote
Old 19-06-2008, 18:18   #2 (permalink)
Joshy
Send a message via MSN to Joshy
From what I hear, it's not cheap.
You'd save yourself a lot of time and money by buying a manual car in the first place.
Joshy is offline   Reply With Quote
Old 19-06-2008, 18:37   #3 (permalink)
Niqui
Niqui's Avatar
the v160 tranny is not a cheap tranny at all unless you went with the R154 and even then from what i am aware of making a auto supra to a standard is not to cheap, youd almost be better off to spend a bit more and get a standard one and save yourself headaches and money
just my thoughts about it
Niqui is offline   Reply With Quote
Old 19-06-2008, 19:29   #4 (permalink)
s12 silvia
s12 silvia's Avatar
to convert a chaser is around £1500 so if its that sort of money im fine with that?
Old 19-06-2008, 19:44   #5 (permalink)
Joshy
From a search on the mkiv forums, it seems like £3000 - £4500 is the figure!
Although I'm not sure if that was parts only, or parts + labour.
Old 19-06-2008, 20:15   #6 (permalink)
s12 silvia
s12 silvia's Avatar
can i use a r154 gearbox on a mark 5 supra tt???
Old 19-06-2008, 20:47   #7 (permalink)
robbs
MANJI MAN
robbs's Avatar
where and who ???? cos i got my eye on an auto chaser
Old 19-06-2008, 20:50   #8 (permalink)
H7ERO
w58 box 150 -200
R154 from mk 3 supra 150-200ish, need a bellhousing too about 250ish
V series 6 speed - 800 - 1500 box only, QSD spares do complete conversion 2300 EVERY single manual part included
Flywheel, master cyl, slave cyl, pedal, prop - 200-250 -either setup
Bridging the auto ECU i just one wire
everything will bolt into place but firewall will have to be drilled 4 the master cyl,
prop wont ba correct unless you use w58 or buy a 6 speed diff with v series, getting the prop modified is only about 70 last time i had it done
brake pedal can just be cut down
pobably have it done in a 2 days if you have all the parts and can spin a spanner
TT autos are really cheap now so are NA manual . . . . so either way building a TT manual can be done on the cheap specially if you use w58
H7ERO is offline   Reply With Quote
Old 20-06-2008, 00:45   #9 (permalink)
Niqui
Niqui's Avatar
yup you can
a lot of people use the R154 over the V160 when they do 2JZ swaps to S-series cars of Rex's, since it's cheaper to do and easier, but depending on the power numbers you want you may want to go with a V160.
So you definitly can use the R154 on the mark 5
Old 20-06-2008, 20:07   #10 (permalink)
s12 silvia
s12 silvia's Avatar
Originally Posted by H7ERO View Post
w58 box 150 -200
who are QSD spairs? have you got a web address for them or contact number?
many thanks
Matt
Old 20-06-2008, 20:18   #11 (permalink)
H7ERO
07779 725 350 is the work mobile i think and they advertise at mkivsupra.net
waiting list i think for conversion, but as always cash will talk as opposed to forum promises
