20-06-2008, 12:58
| #23 (permalink) |
| Flame On!!!! ![]() ![]() ![]() | Gaz is at the breakers in derby. They have a getrag 265, seperate bellhousing, it'll be too long for your prop - 5 speed non dogleg. Also have a 4 speed off an old 633CSi or something, but it's 50mm shorter than the seperate bellhousing 5 speed. Ant reckons he had to shorten the prop 2 inches, 2 inches is 50mm, so it sounds like the 4 speed will bolt up a treat! Should get you going. |
20-06-2008, 13:04
| #25 (permalink) |
| Haha just rang Gaz he's got the 4 speed. I get the impression it's a 262 as I heard they were 4 speed. Gangster yo lol. Thanks for the help nobbon let's hope it works. I'm good to go home in just under 2hrs so hopefully can sort stuff out and get some time to practice tonight ![]() |
20-06-2008, 13:18
| #27 (permalink) |
| Apparently not. The 4 speed is from pre-1980 633csi thingies, it's a getrag 262 which is the same as a removeable bell-housing 265 but minus the overdrive bit bolted onto the back so it should be about the right length and after potentially modding the shifter bracket a bit all should be well. Since it's just the 4 first gears of a 265 getrag it means it's strong as frick. Bllluuh, don't make me get old-skool! |
