Old 20-06-2008, 09:20   #1 (permalink)
gaz_moose
buy my car
-bmw gearboxes-
will a getrag 265 fit a car that previously had a 260/5
like is it the same length box are the input/output shafts the same?
will it fit mikes crappy car as he has a 260/5 and there is a 265 local.
Old 20-06-2008, 09:26   #2 (permalink)
Bon Bon
Flame On!!!!
Bon Bon's Avatar
As long as it's off the back of an M30 then yes.
Old 20-06-2008, 09:28   #3 (permalink)
Bolf
www.manfoot.in
Bolf's Avatar
Quick bit of internet research brings up :
11-27-2006, 09:55 PM
They are different.
1985:
RealOEM.COM BMW E28 535i DRIVE SHAFT (SWIVEL JOINT)
1986:
The 260 and 265 also have very different shifter mechanisms:
1985 (265):RealOEM.COM BMW E28 535i GEARBOX SHIFTING PART
1986 (260):
E28 history
But i've found nothing to suggest they won't be interchangable. Both were fitted to same models/engine.
Bolf is online now   Reply With Quote
Old 20-06-2008, 09:28   #4 (permalink)
ant
R32 GTR-S
ant's Avatar
Send a message via ICQ to ant
that the dogleg one ? if it is its abit wank with a short diff as 5th is 1:1 mine drove like ass with one in
ant is offline   Reply With Quote
Old 20-06-2008, 09:29   #5 (permalink)
Bon Bon
Flame On!!!!
Bon Bon's Avatar
Hmm I've just read something that says they use different length driveshafts but I thought they were the same.
I'm gonna stick with my original statement that they fit exactly the same, 265 isn't dogleg Ant it's just a different code box.
I think the americans are confusing really old school 265s, I'm sure there's a later 265 too. As long as it has the same alloy gear selector support bar thing then I'm sure it'll fit.
Old 20-06-2008, 09:30   #6 (permalink)
Bolf
www.manfoot.in
Bolf's Avatar
Best get the corresponding prop section too.
Old 20-06-2008, 09:33   #7 (permalink)
gaz_moose
buy my car
do i need the prop bon?
the 265 has the removeable bellhousing?
Old 20-06-2008, 09:36   #8 (permalink)
Bon Bon
Flame On!!!!
Bon Bon's Avatar
By the way I tried to ring you a little while ago gaz.
Erm if it wasn't a "do or die" situation I'd say no, what prop is mike using? 265 is listed as the E30 M3 box too, so in that case if he's using an E30 M3 prop, common sense would say no.
Also E30 props should have a sliding section to accomodate differences in box length.
Ask him what the gear selector on the back looks like, if it's the usual split pin holding on an alloy rod with the gearstick in the rear in a cup then it's the right box and will fit.
If it's got a stupid big triangular shaped support flapping around on the back then I'd not be confident at all.
Old 20-06-2008, 09:39   #9 (permalink)
ant
R32 GTR-S
ant's Avatar
if its the same as my 265 then the box is longer, mike did have my shortened prop that fits it but i dont know what he did with it
Old 20-06-2008, 10:11   #10 (permalink)
gaz_moose
buy my car
i tried calling that place in coaville and couldnt get through
the guy in cov had no boxes either
the breakers in derby have the box with the romoveable belhousing what do i do? lol
Old 20-06-2008, 10:14   #11 (permalink)
Bon Bon
Flame On!!!!
Bon Bon's Avatar
Ring mike on his mobile that he hasn't got with him - dumbass - and ask him if he's still got the shortened prop.
Or e-mail him I guess.
Old 20-06-2008, 10:17   #12 (permalink)
sideways.taff
-NightWalkers-
sideways.taff's Avatar
Did Mike give you his work phone number? I've got that one if you need it?
Old 20-06-2008, 10:23   #13 (permalink)
gaz_moose
buy my car
i have his work phone number which he dont answer!
will the prop lengthener thingiy have enough give in it to compensate the extra lenth of the e28 box?
Old 20-06-2008, 10:32   #14 (permalink)
ant
R32 GTR-S
ant's Avatar
no i had to shorten an e30 m3 prop to get it in
Old 20-06-2008, 10:38   #15 (permalink)
e30 of Death
But the e28 box you had was a dogleg one ant, the normal e28 boxes are different IIRC as they are the same as 525i/528i etc? So perhaps that box is the same length as a 265.
Not sure what linkage is on the box Gaz will have to find out when he gets to the breakers in about an hour.
Old 20-06-2008, 10:54   #16 (permalink)
Bon Bon
Flame On!!!!
Bon Bon's Avatar
Didn't moffatt drop one of my E28 265s in to his E34, straight fit? Pretty sure he did.
Old 20-06-2008, 11:21   #17 (permalink)
ant
R32 GTR-S
ant's Avatar
mine was an e30 m3 one just to confuse things
Old 20-06-2008, 11:25   #18 (permalink)
e30 of Death
Just checking some random but intellectual looking forum post, it seems that the very early overdrive 265 boxes and the dogleg "sport" 265 boxes were both longer than the 260, but it seems the conventional 265 is the same dimensions.
I never directly swapped my 265 for a 260/5 but I juggled engines which were fitted with both and they always seemed to be the same sort of box. Hopefully all will work out and I'll have a bit of trivia for us all.
Anyone know how to rebuild a 260 gearbox?
Old 20-06-2008, 11:27   #19 (permalink)
Bon Bon
Flame On!!!!
Bon Bon's Avatar
Give it to a gearbox place and say rebuild please.
Or smash it to frick and get another one for 50 quid.
Old 20-06-2008, 12:03   #20 (permalink)
e30 of Death
I'll probs take it apart just to have a look if it's definately toast, if I can. Never looked inside a gearbox before!
I feel useless for being stuck at work when my boyo's are running around fixing my car for me Hope we get it sorted!
