20-06-2008, 18:22
| #2 (permalink) |
| JDM retro FTW ![]() Join Date: Aug 2005 Location: Bedford
| Basically, you can fit it anywhere between the turbo & throttle body. The idea for a bov is to stop compressor stall & reduce lag between gears (nothing to do with vroom-tishhh, right ). It'll be most efective if fitted nearer the throttle body, but if you just want the noise it doesn't really matter |
20-06-2008, 18:25
| #3 (permalink) | |
| tail slider | Quote:
21-06-2008, 06:35
| #9 (permalink) |
| talent bypass ![]() ![]() Join Date: Jul 2004 Location: Essex
| Depends on the DV. Some leak on idle causing the engine to hunt and in my experience they can cause over fuelling when changing gear. I used to have one on mine years ago but binned it because you could feel the car bogging down as you floor it after a gear change. I could get rediculous flamage though. ![]() |
21-06-2008, 14:13
| #12 (permalink) |
| dorifto kingu! ![]() Join Date: Jun 2007 Location: sunny Texas!
| I bought one greddy look-a-like for my RX7 - was leaking like hell, even closed completely was hissing like a mad snake, car was over fueling and hunting - mad house! so I changed it for a real mccoy - worked the treat! as you said - you get what you pay for.... |
22-06-2008, 11:01
| #16 (permalink) |
| touge runner Join Date: Nov 2006 Location: ulverston, cumbria
| well i was thinking of removing mine, a bailey dump valve, but if i do what do i do with the small hose that comes from the top of the valve to the inlet? just blank it off? also i am running a boost gauge from this pipe, so will this affect the gauge or can it stay where it is ![]() Last edited by owent : 22-06-2008 at 11:38. |
