Old 21-06-2008, 15:13   #1 (permalink)
Monkey Magic
Monkey Magic's Avatar
DW coilovers camber problem
Got the car aligned today, everything went well apart from the front camber.
The drivers side is adjusted as far over as it can go and the most amount camber we achieved is -2.13 on that side but the passenger side had plenty more to go so we set them both at -2.13.
I had a set of jic majic shocks with top mounts before the DW coilovers and they were fine so I am a little confused why this has happened
Heres a few pics of either side
Drivers side adjusted as far as it can go
Passenger side with room for adjustment
Monkey Magic is offline   Reply With Quote
Old 21-06-2008, 19:51   #2 (permalink)
Maximus Driftus
Maximus Driftus's Avatar
bit confused here - to increase the camber the tops should point towards the engine bay not out? from your pics it looks like you trying to zero it out? but - if both of the sides are on the same angle and you still have adjustment left on one of them (whichever way) and the other one is on the limit it suggests your car had front end kisskiss...
Maximus Driftus is offline   Reply With Quote
Old 21-06-2008, 20:04   #3 (permalink)
Phil
7JZGTE
Phil's Avatar
Yeah very confusing. Do you mean you want less camber? The difference left to right is quite common as there are very few truely straight cars out there (even from new). There is possibly a real small amount of movement where the bolts go into the hub.
I guess to help you out first we need to know your desired settings and what arms you have on the car
Phil is offline   Reply With Quote
Old 21-06-2008, 20:10   #4 (permalink)
superclarkey
Mood=Badical!
superclarkey's Avatar
you may find that one of your lower arms may be bent.. i would have a good look at your arms on the front for any signs of bentness.
IF nothing found if you get the work shop manual it shows you how to messure the front up to see if its ok.
I've fitted loads of the driftworks gear to most cars, and i've not found there ever to be a difference like that... so give it a good look at your lower arms and your tention rods, also messure the position of the wheel in relation to the body to make sure its in the same place on both sides.
Clarkey.
Old 21-06-2008, 20:11   #5 (permalink)
kam
kam's Avatar
Dont you mean you want more camber?
But one side will only go to -2.13 so you set them both to that?
My car is the same, one side will go to -2 something and the other -3 something......
kam is online now   Reply With Quote
Old 21-06-2008, 22:53   #6 (permalink)
steady eddie
steady eddie's Avatar
Looking at the pics you have the camber set at the minimum negative... you need to adjust the other way to get more neg camber.
steady eddie is online now   Reply With Quote
Old 21-06-2008, 23:17   #7 (permalink)
colour-flip
colour-flip's Avatar
i had mine done today also
got max deg camber from the top mounts and was -2.3degrees with the caster on 8 degrees and toe on 0.10degrees
both sides are totally the same with both struts as fars towards the engine as poss..
deff looks like you have got some problems with the arms on the car
colour-flip is offline   Reply With Quote
Old 21-06-2008, 23:18   #8 (permalink)
colour-flip
or had it aligned by monkeys
Old 22-06-2008, 00:43   #9 (permalink)
Monkey Magic
Hi sorry to confuse everyone with the first post but I was trying to get less camber than what we ended up with. I wanted to get -1.5 but we could not achieve anymore than -2.13 ie Less camber
I am setting the car up to go on track soon and from some research on sxoc I decieded on these settings below although I'm not entirely sure whever they are ideal for my setup so any advice is welcome
These are the settings I went in with, I wasnt sure on the front camber and was going to ask for advice off the alignment guy but didnt get anything usefull out of him
I was aiming for handling primarily but wouldnt mind something thats a bit tail end happy so I thought a minimum amount of toe would be good for that
FRONT
castor 7.30
camber -1.3 to -1.5
toe 0.02
REAR
camber -1.1
toe 0.02
Car suspension setup :
Apex adjustable rose jointed arm kit
Apex top and lower strut bars
Apex full bush kit & subframe locking collars
Apex engine & gearbox mounts
Whiteline antiroll bars
Tein rods & k-sport ends
I read somewhere that the harder the suspension setup the less camber you need compared to a softer setup - Is this true?
Old 22-06-2008, 00:48   #10 (permalink)
Monkey Magic
Someone on sxoc has mentioned this, I shall give it a try and report back
