26-06-2008, 19:02
| #4 (permalink) |
| tail slider Join Date: Apr 2008 Location: Netherlands, in Maastricht
| It sounds more like BE's brother, tappets make it sound like a diesel, really, almost the same however BE make a marbels rattling around sound which your seems to do ![]() However if its tappets, I wrote a complete How-To on SXOC named: How To: Change your hydraulic lifters .. or something, can't find it as I'm banned ![]() |
26-06-2008, 20:33
| #8 (permalink) |
| SkidSkidWinWin ![]() Join Date: Jun 2006 Location: Essex Drift Union FTW!
| Sound's identical to big end's but....... Mine has started a very small sound similar to your's from the rocker's until the engine is at full running temp. I believe it's to do with all the limiter bashing ![]() If your certain it's from top end and not bottom, change your hydraulic lifter's ![]() |
26-06-2008, 20:38
| #9 (permalink) |
| i do skids ![]() Join Date: Jul 2006 Location: Grantham
| that's BE i reckon...mie did much the same...now ive got top end knock and it drops off after the block heats up...where as BE rattle stays all the time, hold it at 3k and if it's still as loud...get the sump off!!! |
27-06-2008, 16:15
| #13 (permalink) |
| To replace the BE's its easier to just take the engine out. It works better, neater and in the end its faster than you might expect. Taking the engine out isn't as much work as the phrase makes it sound. Most people get shivers upon hearing 'taking the engine out' , don't want to brag but its not that hard. Not to mention, on my LHD I tried and tried getting the sump out with engine in but with no luck. And hell if I could get it out (which should be possible somehow..) I wonder if I could get it in properly with the instant gasket and all. |
