Old 27-06-2008, 00:13   #1 (permalink)
shirunai
shirunai's Avatar
Where to install the hydraulic handbrake?
Where should I install it, This aint another where should I plump in the handbrake, but where should I put it, I have a eu spec s13 and no plastic on the transmissiontunnel, should I put it there? How did you do it I guess this is a picture request thread bring those hydraulichandbrake installation pictures
shirunai is offline   Reply With Quote
Old 27-06-2008, 00:25   #2 (permalink)
e30 of Death
I pulled my standard handbrake out, fitted my hydro there. Just take any trim out of the way, rest your handbrake somewhere and try turning the steering wheel as if you'd be drifting, and change gears etc, and see if it gets in the way.
I was just spazzing out in the cockpit and figuring out a place it wouldn't be in the way, with my e30 not having much room it just ended up replacing the standard handbrake.
MJG is online now   Reply With Quote
Old 27-06-2008, 00:37   #3 (permalink)
shirunai
shirunai's Avatar
I think I want my handbrake where it is it still some sort of a streetcar even tho I dont run it for shopping or going to mall etc.
Old 27-06-2008, 00:51   #4 (permalink)
David Wilson
David Wilson's Avatar
If your car is road legal then you must leave your cable hand brake in place and connected. My hydro is the opposite side of the gear stick sticking up so when you change down from 3rd to 2nd the brake is right in your hand should you need it.
David Wilson is offline   Reply With Quote
Old 27-06-2008, 09:55   #5 (permalink)
sideways.taff
-NightWalkers-
sideways.taff's Avatar
