Old 27-06-2008, 22:56   #1 (permalink)
THICK SOUP
REDNECK RACING
THICK SOUP's Avatar
Send a message via MSN to THICK SOUP
Seam sealer removal
Just wondering how you guys are getting the seam sealer out so you can seam weld the chassis.
I've done a search but did'nt find anything on what people are using, just referances to grinding/wire brushing or burning it out.
Does the grinding/wire brushing get it clean enough for a good weld?
What sort of gas tourch do you use for burning it out?
THICK SOUP is offline   Reply With Quote
Old 27-06-2008, 23:08   #2 (permalink)
Sweeps
Sweeps's Avatar
I used wire wheels, takes a lot of time though and a lot of wheels, does the job but not perfect.
Sweeps is offline   Reply With Quote
Old 28-06-2008, 00:32   #3 (permalink)
RED
RED's Avatar
I used a wire brush/grinder/chisel/small malnourished orphan to get all the seam sealer out. It took a while but it worked!
RED is offline   Reply With Quote
Old 28-06-2008, 10:48   #4 (permalink)
gaz_moose
buy my car
wire wheel although you can get wire wheels that have some resin type shit on em so that the bristles dont fly off we used to call em 'muel skinners' then burn the remaining bits out.
dont forget to constantly remind yourself 'this is fun right?'
Old 28-06-2008, 13:30   #5 (permalink)
THICK SOUP
REDNECK RACING
THICK SOUP's Avatar
So wire wheel seams to be the way to go, thats good I've got a butt load in my tool box at work.
Thanks for the replys
