Old 02-07-2008, 21:33   #1 (permalink)
caged
Drift Gibbon
caged's Avatar
Help with diff please.....
toyota LSD, draws a big number 11 up the road, draws even bigger ones out of junctions, but when i attempted a donut it would kinda struggle, seeming to swap drive to one wheel then t'other.
NB: the donut was attempted on rough shitty tarmac that could have been different under either wheel.
Is it worn - if so why is it being highlighted in this way and not through not even being able to do a number eleven? In a straight line it will draw an 11 for a good 100feet, same outta junctions.
what can be done to sort this?
sensible answers only pls!
caged is offline   Reply With Quote
Old 02-07-2008, 23:49   #2 (permalink)
neil a walker
neil a walker's Avatar
doubt its worn out mate, they ususally have quite a good lifespan and prev owner prob wouldnt have worn it by skidding. maybe the rough ground plus hard rear shocks made gripping a bit skippy so wotever wheel had the most grip at the time made it feel a bit sporadic. Try it on a better bit of tarmac. What was the handling like? body roll and understeery or flat and direct?
neil a walker is offline   Reply With Quote
Old 02-07-2008, 23:51   #3 (permalink)
superclarkey
______________
you need to find someone that can weld and get it welded mate
Old 02-07-2008, 23:55   #4 (permalink)
e30 of Death
Not a Torsen is it?
Old 03-07-2008, 00:10   #5 (permalink)
superclarkey
______________
i think it will be
Old 03-07-2008, 06:47   #6 (permalink)
G-Man
i do skids
G-Man's Avatar
booo...
If it's the same diff as on the JZs then it's a torsen.
weld it!
G-Man is offline   Reply With Quote
