Old 02-07-2008, 23:17   #1 (permalink)
podge07
podge07's Avatar
Send a message via MSN to podge07 Send a message via Yahoo to podge07
clutch
sometimes when i clutch in the car lately the pedal aint coming back up fully any body anyideas wat i problem is thanks podge
podge07 is offline   Reply With Quote
Old 02-07-2008, 23:33   #2 (permalink)
superclarkey
______________
You need to bleed your clutch.. or the slave is sticking..
Old 02-07-2008, 23:37   #3 (permalink)
podge07
podge07's Avatar
clutch being bleed the weekend fitting the braided hose wat cause the slave a be stuck is fcuked or can it be oiled up anywhere
Old 02-07-2008, 23:39   #4 (permalink)
superclarkey
______________
If water gets into it then it will rust the cast casing and the bronze insert will foul, you can normaly take them apart and give them a light clean and they are as good as new.
sometimes the clutch dampner leaks, i would fully remove it.
The braided line only replaces the short bit of rubber from the dampner to the slave.. if you want to remove the rest of the crap you must use some copper line.
Check the arm into the box is not bent also while your down there, as the pedal normal sticks if the stroke on the arm is too much.
Clarkey.
Old 02-07-2008, 23:43   #5 (permalink)
podge07
podge07's Avatar
Clarkey.
ill try tis the weekend water sometimes get into engine and as no cowlings left in front
ive thhe braided line tat goes from the master cyclinder to the slave cyclinder so tis will get rid of the dampener i think tat is the small box at the end of the steel pipe isnt it
is tis the steel arm tat stick out of the side a the box
thanks for the help
Old 02-07-2008, 23:46   #6 (permalink)
superclarkey
______________
yeah thats correct.
Just check for free play in the arm also, when you remove the slave off the side of the box, just give it a wiggle, and see if it has lots of play. it will have a bit of play but no massivly.
But my money is on poor fluid or just needing a bleed up.
Clarkey.
Old 02-07-2008, 23:47   #7 (permalink)
podge07
podge07's Avatar
yeah thats correct.
Clarkey.
thanks man is 5.1 best to use in it or just ordinary for it
Old 02-07-2008, 23:49   #8 (permalink)
superclarkey
______________
5.1 will take more heat... but will be more prone to catching water.. but saying that you would not keep the car long enought to see the difference between the two
just change it ever 6months or when it turns dark
dark fluid = water in it.
Old 02-07-2008, 23:51   #9 (permalink)
podge07
podge07's Avatar
ordinary it is so plus ive dark fluid as it is thanks for your help man
