03-07-2008, 12:56
| splendiferous Join Date: Mar 2006 Location: Glasgow
| Why run a staggered size? Why do RWD cars from factory have a narrow front tyre width and wider rear width? Is it not better to run the fronts as wide as the back as most folks do when they start modifying from the original spec? Anyone know why RWD cars come from the factory staggered like this? |
03-07-2008, 13:54
| #5 (permalink) |
| A silly but well to do mate of mine kept nagging at me for running 225s all round as apparently "staggered is correct from factory for RWD, they know better". I replied it's probably because they dial in understeer deliberately and it saves them tyre costs as the front wheels have no driven power, I wasn't ever told this it just sounded logical to me. Just wanted to double check so I can bitchslap him next time . |
03-07-2008, 13:59
| #6 (permalink) |
| tail slider Join Date: Dec 2006
| your dead right, as starvos said, factory cars are made to be safe for the genral public, and understeer is safer than oversteer for an inexperienced driver, tried this with my ex misses, she drove her car round a corner and put her foot down and got it understeering, she just lauged and carried on, then she did it in mine and it kicked out a little and she near on burst into tears cos she thought she was going to die lol. |
03-07-2008, 14:00
| #7 (permalink) |
| Libertine ![]() Join Date: Aug 2004 Location: Bat Country
| Its a good way of easily tuning grip levels, some cars (a lot of toyotas) have a narrower track at the rear too. Narrower tyres on the front give you more steering feedback. Some cars (especially MR stuff like MR2 or Elise/Exige) handle a lot better with the same tyre type and size all round, and staggering it makes them twitchy(er) For general stuff I like running the same all round for balance and predictability, although ultimately its down to driver preference and it varies depending on the type of car (light/chassis) what has been done to the suspension and how its been set up etc. |
03-07-2008, 14:24
| #10 (permalink) | |
| -NIGHTSPIRIT FAMILY- | Quote:
I dont think any Elises come with the same size tyres and I dont think anyone changes them to be either. S1 Elises are 15inch front 16 inch rear with a narrower front tyre (dont know sizes). S2 an inch bigger diameter respectively. The VX220 got 17s allround cause Vauxhall prefered the look and wanted to cheapskate it. Its considered better to go back to the Lotus setup on aftermarket wheels. | |
03-07-2008, 15:57
| #12 (permalink) |
| It seems on FR cars it's better to run equal size all round but on MR/RR it's heavily recommended to run staggered sizes. Having owned 2 MR cars myself (MR2 and an Elise) I noticed everyone was running a staggered setup when viewing their setups. In fact Lotus owners very very rarely change from the stock wheels/tyre sizes. On MR cars the alloys on these vehicles are themselves narrower at the front and wider at the rear. Seems to be more acceptable and proven on FR cars to be benificial when running equal size tyres all round. I can only see it as being related to the difference in weight distribution due to engine location. |
03-07-2008, 16:12
| #13 (permalink) |
| EDC実況 | Bringing this into a slightly drifty context... Have you noticed that most drift silvias in Japan run a 18" wheel setup rear and 17" front? also the width is considerablly different. I had thought it's down to the level of grip offered on the rear with the big wide tyres is about equal to the fronts on smaller narrower ones meaning it could slide all 4 wheels in a balanced fashion... any thoughts on this? In the reverse situation, A lot of Japanese tuners stick slightly wider 16" wheels on the front and narrower 15" wheels on the back of Civics. I can understand this one as to drive FF fast you want the back to pretty much just come along for the ride and is fastest when slightly loose. |
03-07-2008, 17:48
| #15 (permalink) |
| D1 street king Join Date: Mar 2006
| Has anyone ever ran wider tyres at the front in favour of the rear? I run 195 all around and I got used to this setup. With the new rear arms I can set it now to 0 camber at the back so no longer need to change setting with tyres and wheel size only. I always had the impression that even you reduce the rear width, wider tyres at front will still make it understeer with sudden snappy oversteer. |
03-07-2008, 21:04
| #16 (permalink) | |
