Old 10-07-2008, 19:04   #1 (permalink)
shirunai
shirunai's Avatar
Hydraulic handbrake issue
Hello I have installed a hydraulic handbrake (dw one with wilwood Master cylinder) to my nissan 200sx rs13 its really hard to lock up the wheels u need so much levrage so you get unfocused if you want to lock up the wheels, we have bleeded today with no bubbles at all.
What todo? is the rear orignal brakesetup and blackstuffpads to weak?
Regards ANdré
edit: additional information the mastercylinder is 0.625 something if I remember correctly, other than the driftworks handbrake the brakesystem is completly orignal got a facelift rs13 if that helps. The bleeding procdure was like this open valve, depress brake and depress handbrake and close did this severaltimes to get no bubbles in the system.
shirunai is offline   Reply With Quote
Old 10-07-2008, 19:12   #2 (permalink)
royal
S1- F.T break!
Must still be air in there or something? my hydro completely locks the wheels at any speed.
royal is online now   Reply With Quote
Old 10-07-2008, 19:24   #3 (permalink)
ChizFab
bleed bleed and bleed again mate.
ChizFab is offline   Reply With Quote
Old 10-07-2008, 19:30   #4 (permalink)
SteveC200
talent bypass
SteveC200's Avatar
Youre pulling the handbrake and the pedal at the same time? Try doing them seperately.
SteveC200 is online now   Reply With Quote
Old 10-07-2008, 19:36   #5 (permalink)
shirunai
shirunai's Avatar
how do you mean seperatly ? explain exaclty how to bleed we were two people.
1Open valve
2depress brake pedal some times keep it pressed
3pull handbrake keep it pulled
4close valve
And repeat so you dont see airbubbles.
Old 10-07-2008, 20:12   #6 (permalink)
royal
S1- F.T break!
Might just be the english, but are you sometimes letting it go? you are pushing it down and KEEPING it down arn't you? Still sounds like it just needs more bleeding though. If you think about how much extra brake lines you are adding. you need to get all that air out.
Old 10-07-2008, 20:18   #7 (permalink)
shirunai
shirunai's Avatar
adding? there isnt alot of more brakelines to add, since I am tapping it in on the on the ABSactualtor to the handbrake and then back to the T-peice.
I have a Non-return valve/check valve and a hoose and a bottle.
When I open the brakevalve
my mate is depressing the brakepedal few times until we get fluid in the hose and not letting go of the brakepedal, after that he pulls the hydraulic handbrake and not letting it go after that i close the valve and he lets go of the handbrake and the footbrake
and we repeat until we dont see any bubles.
Old 10-07-2008, 20:24   #8 (permalink)
royal
S1- F.T break!
You shouldn't press it up and down with the valve open because it will suck air in.
Open valve,
Press pedal down and hold down (same with hydro)
close valve
Repeat
Old 10-07-2008, 20:28   #9 (permalink)
shirunai
shirunai's Avatar
just press one time on the footbrake and keep it depressed and pull handbrake and keep it there and close valve ?
Or should I do them separatly?
open valve
press footbrake and keep it there
close valve
or
open valve
press footbrake 1time and keep it there
pull handbrake 1time and keep it there
close valve
let go
open valve and do it again?
Old 10-07-2008, 21:00   #10 (permalink)
JackMcIntyre
JackMcIntyre's Avatar
Send a message via MSN to JackMcIntyre
I've not had practical experience bleeding anything but just through thinking about it the second option sounds like it would get air bubbles out.
JackMcIntyre is offline   Reply With Quote
Old 11-07-2008, 13:08   #11 (permalink)
shirunai
shirunai's Avatar
The handbrake works better now I guess, should I do the same procedure on the front calipers? we have just pressed the pedal on the front with no bubbles what so ever.
If the handbrake is going to work nicely i have to push the pedal, if I do this the handbrake gets superstiff and grips right away if I dont do that I have a 5-10mm travel until the handbrakes bites, is this due to unbleeded brakes?
Should I just bleed bleed bleed and pump another 1liter of fluid in it ?
Regards ANdré
Old 11-07-2008, 13:15   #12 (permalink)
MR-steveo
TNS MAN CHILD
i had the same problem for ages, got pissed off and brought a proper master cylinder, an ap racing one,
bleed in 30 seconds and it the bollox now!
Old 11-07-2008, 13:24   #13 (permalink)
royal
S1- F.T break!
Because you've got the hydro on the same circuit as the footbrake they affect each other in the way you mention. I did find I had to bleed mine again a week later which reduced the amount of travel, but they will always affect each other. I found I got used to it very quickly and rarely have any issues. Usually when you pull the handbrake you are footbraking anyway to shift the weight forward so it works out ok.
Old 11-07-2008, 13:25   #14 (permalink)
royal
S1- F.T break!
Hello mate,
In what way did the AP master cylinder improve things? can you bleed it differently or something?
Old 20-07-2008, 11:03   #15 (permalink)
shirunai
shirunai's Avatar
My handbrake is alot better now, you have to warm up the rear brakes first by pulling the handbrake a few times then its get alot better, I also use a big screwdriver in the driftworks handbrake lever to make even more levrage, the aluminium handbrake lever is bent tho I will fabricate one in thick 6-8mm steel and increase the length by 300mm
