Old 17-07-2008, 16:20   #1 (permalink)
TwinturboCH
TwinturboCH's Avatar
Send a message via ICQ to TwinturboCH Send a message via MSN to TwinturboCH
Want to 5-stud a R32, which hubs can i use?
Simple question really, can I use S14 ones or do they have to be Skyline etc etc. I need to swap 4-stud ones on a 4-door R32 for 5-stud ones.
Same goes for the brakes, what cars can i get them from?
Thank-you-please
TwinturboCH is offline   Reply With Quote
Old 17-07-2008, 16:49   #2 (permalink)
Brunosr13
Brunosr13's Avatar
Thank-you-please
With out any problems mate, I have on my car, will be good if also you can have a front lower arms, rear just replace the hub and drill the stock discs, you can use the front brakes just need swap the flexi pipe.
Brunosr13 is online now   Reply With Quote
Old 17-07-2008, 20:13   #3 (permalink)
TwinturboCH
In english?
LOL joking, I think i get what you mean. Thanks, but could anyone be totally clear about what bits I can use as I have an my old stripped S14 shell sat here that i could rape for the parts.
Old 17-07-2008, 20:22   #4 (permalink)
Mitch
Driftgarage
Mitch's Avatar
You can use the S14 rears but need R32 fronts.
Old 17-07-2008, 21:36   #5 (permalink)
Dex
kut!
Dex's Avatar
Send a message via MSN to Dex
no you need to keep it 4 stud, and sell it to me
Old 18-07-2008, 11:06   #6 (permalink)
gaz_moose
buy my car
get some r32gtst front hubs they should be 10 a penny
then get these bits off your breaker
rear hubs
front lower arms
front calipers
brake master cylinder
then just drill your rear discs to 5 stud
Old 20-07-2008, 16:27   #7 (permalink)
TwinturboCH
If I found R32 hubs for front and rear, what other stuff would i need?
Just brakes?
Old 20-07-2008, 18:57   #8 (permalink)
gaz_moose
buy my car
just brakes unless you drill your discs to 5 stud
Old 20-07-2008, 18:59   #9 (permalink)
TwinturboCH
Sweet Thanks guys, may well have more questions later LOL
