Old 19-07-2008, 19:40   #1 (permalink)
topi
Shh Cha Muhf
topi's Avatar
Brake upgrade on the S13
I'm fed up of my brakes not working after short country lane blasts, so I think I need to upgrade before I end up in a field.
I understand the 300zx 4pots fit right? Would they fit under my 15" SSR wheels though? And what about discs?
Cheers.
Old 19-07-2008, 19:47   #2 (permalink)
jdmash
jdmash's Avatar
by the new brakes and i will have ur wheels yeah
jdmash is offline   Reply With Quote
Old 19-07-2008, 19:50   #3 (permalink)
topi
Shh Cha Muhf
topi's Avatar
I'd rather cook my brakes, end up in a field and sit there looking awesome with badass wheels hahaha
Old 19-07-2008, 19:57   #4 (permalink)
jdmash
jdmash's Avatar
guess i will have to pinch them then
Old 19-07-2008, 19:58   #5 (permalink)
Padi
Padi's Avatar
i like your style!
haha
Padi is offline   Reply With Quote
Old 19-07-2008, 21:18   #6 (permalink)
LiGhTnInG
Doricomotion
LiGhTnInG's Avatar
Upgrade your fluid to dot5 and use a 300zx brake master cylinder. You wouldn't believe the difference.
Old 19-07-2008, 21:30   #7 (permalink)
Rhys_sx
if u use a 280 disc on s14 4 pots think they fit behind 15's depending o spoke design
Rhys_sx is offline   Reply With Quote
Old 20-07-2008, 09:44   #8 (permalink)
gaz_moose
.MTM.
you got no chance of getting brakes to fit under those front wheels.
what size discs do you have at the moment 265 or 280?
id guess by how dirty your front wheels always are that your front pads are lame just like your game.
maybe your brakes are poor because there aint no hard pipes in your setup yo!
Old 20-07-2008, 09:54   #9 (permalink)
e30 of Death
I'd just give them fresh pads, fancy fluid (isn't it dot5.1 fluid, as dot5 is some weird type of fluid that kills you for old cars?), and braided lines etc. They shouldn't cook on country lanes lol.
MJG is online now   Reply With Quote
Old 20-07-2008, 12:30   #10 (permalink)
Jimthejunior
Represent
Jimthejunior's Avatar
I thought hard lines(copper)>braided lines
Old 20-07-2008, 12:31   #11 (permalink)
e30 of Death
Well yeah but you need braided lines from inner arch to hub
Old 20-07-2008, 12:32   #12 (permalink)
topi
Shh Cha Muhf
topi's Avatar
Ok mothalovas, I'll just rebuild my standard sheezeys and maybe route some cooling to them aswell. Matt gave me some funky wapanese brake pads, so I'll disc and line her up with some new seals.
Old 20-07-2008, 12:33   #13 (permalink)
e30 of Death
Sounds good man, then at least you won't have any problems with fitting stuff or buying expensive stuff.
Old 20-07-2008, 14:11   #14 (permalink)
gaz_moose
.MTM.
yeeah mann one pots ftw
Old 20-07-2008, 14:18   #15 (permalink)
topi
Shh Cha Muhf
topi's Avatar
I can't find any rebuild kits, I guess everyone just ditches them haha
Old 20-07-2008, 14:27   #16 (permalink)
retrodan
celebs in car
retrodan's Avatar
a real man, would fit wheels with such offset the the disc is inside the wheel, thus letting u run massive discs, prolem solved
Old 20-07-2008, 14:31   #17 (permalink)
topi
Shh Cha Muhf
topi's Avatar
Hahaha, I see your idea. But I shall not take man advise from a southerner! hehe
Old 20-07-2008, 14:37   #18 (permalink)
retrodan
celebs in car
retrodan's Avatar
oooooooohhhhhhhh eeeeeerrrrrrrr
Old 20-07-2008, 14:46   #19 (permalink)
HellaFlush
TeamLifestyler
Topi.. Im 99% sure ive got drilled and grooved 280mm discs, and they fitted behind my lameass 15" steels when i was waiting for new rimzorz?
Are you running facelife, or prefacelift discs?
HellaFlush is offline   Reply With Quote
