Old 04-08-2008, 10:02   #1 (permalink)
andy-ae86
andy-ae86's Avatar
boost up
is there anyway to turn the boost on your car 180sx (blacktop) with out a remap or boost controller ive heard you can use a bleed valve does anyone have any more info that might help me thanks
andy-ae86 is offline   Reply With Quote
Old 04-08-2008, 18:45   #2 (permalink)
YashioFactory
YashioFactory's Avatar
lol
a bleed valve is a boost controller.
you dont need a re-map to increase the boost.
you can turn the boost up by a bleed valve or dawes device. these are cheap, cost about 20 quid, but do the job.
if you are a tight arse, you can put washers on the turbo wastegate, so the turbo opens sooner/later.
id get a dawes device persoanlly.
or if you have the cash an electronic one, like an Apexi AVCR or GReddy profec.
you will find tho that you may need to chip the ECU, as more boost required more fuel. (chip is same as remap)
YashioFactory is offline   Reply With Quote
Old 04-08-2008, 19:53   #3 (permalink)
Stavros
DEYTUKURJURBS
Stavros's Avatar
no its not
Old 04-08-2008, 20:26   #4 (permalink)
YashioFactory
yea know not exactly,
but i meant they both alter the ECU to provide more fuel
Old 04-08-2008, 20:34   #5 (permalink)
shane
shane's Avatar
Be very carefull how much you turn your boost up. Small increases aren't a problem, but to much and pop. If you want alot more power then other stuff will have to be done.
shane is offline   Reply With Quote
Old 04-08-2008, 22:36   #6 (permalink)
andy-ae86
andy-ae86's Avatar
thanks lads my problem is the car is boosting at 0.4 which is ok but io just wanted it up to 0.7 is all give her a little bit mroe till i get my s15 turbo
and iam not a tight arse lol was just wondering as it will be a few weeks before i can get boost controller
so is the bleed valve a safe method
Old 05-08-2008, 10:15   #7 (permalink)
YashioFactory
yes safe,
whats the rest of the cars spec?
exhaust, filter?
when i decated, exhaust, filter, i needed a chip, becasue the car was overfueling and hitting fuel cut
exhaust, filter turns the boost up on its own!
you maybe able to turn it up slightly without the car overfueling and hitting fuel cut.
Old 05-08-2008, 10:44   #8 (permalink)
andy-ae86
andy-ae86's Avatar
well it has yashio factory 1.3 bar rad greedy intercooler some kinda air filter that connected to the air flow sensor has exhaust system from turbo back with down pipe the car has plenty of poke i just wanted to have it up to 0.7 wanta see what shes like at that.
is a bleed vavle hard to use or is it straight forward ?
Old 05-08-2008, 11:32   #9 (permalink)
YashioFactory
easy,
you just cut a pipe on the turbo in half, then plug each half into the bleed valve.
then you just turn the valve to increase the boost.
you NEED a boost gauge tho!
Old 05-08-2008, 12:04   #10 (permalink)
boo_kong
boo_kong's Avatar
just remember dude'
when turning the bost up with a bleed valve' do it 1/4 a turn at a time.
Every time you turn it up go out in your car, stick it in 3rd at low revs and then floor it right the way thru 3rd gear.
If you get any backfire at all or the car holds back its BADDDDDDDDDD'
Thats (over boost) and WILL kill your car.
If you get any over boost at all turn the valve back down............
boo_kong is offline   Reply With Quote
Old 05-08-2008, 17:42   #11 (permalink)
andy-ae86
andy-ae86's Avatar
nice guys i do have a boost gauge so shouldt be a problem
Old 05-08-2008, 17:55   #12 (permalink)
andy-ae86
andy-ae86's Avatar
hey was gona ask has anyone used a dw manuel boost valve see it in the shop looks like the right peace of kit ?
Old 05-08-2008, 18:46   #13 (permalink)
robbs
MANJI MAN
robbs's Avatar
^^^^^^^^^^^^that is a bleed valve^^^^^^^^^^
Old 05-08-2008, 18:52   #14 (permalink)
andy-ae86
andy-ae86's Avatar
well in the dw shop it says its not have a read of it man
Old 05-08-2008, 18:56   #15 (permalink)
robbs
MANJI MAN
robbs's Avatar
well its pretty much the same thing but probably just a good quality item, anything DW sell can be trusted as the try and test everything they sell.
Old 05-08-2008, 18:58   #16 (permalink)
YashioFactory
bleed valves tend to spike.
the DW valve is a DAWES DEVICE.
they are better as dont tend to spike.
DW do one, or there are loads on ebay.
ball and spring controller = dawes device
Old 05-08-2008, 19:23   #17 (permalink)
mitsi_matt
mitsi_matt's Avatar
i have a thrust/greddy one for a few beer tokens if u are interested!
mitsi_matt is offline   Reply With Quote
Old 05-08-2008, 22:16   #18 (permalink)
andy-ae86
andy-ae86's Avatar
how many tokens man will it go into a 180?
Old 05-08-2008, 22:21   #19 (permalink)
YashioFactory
they are all universal m8
Old 06-08-2008, 17:23   #20 (permalink)
steve_fctuning
be really careful with the bleed valve mate.
try if you can to do it properly. i know you may be on a budget but it could cost you more in the long run.
Watch for boost spike in 4th gear under 100 percent load if your choosing to use this crude method
