Old 06-08-2008, 20:23   #1 (permalink)
topi
KlutchKickKidz
topi's Avatar
Fuel + Spark but not firing?!
Help needed. (SR20)
My car was running mint, and then it was left of my drive for a week. Went to move it... fired up and died..
I've got fuel (put an extra jerry can in incase), which is getting to the plugs. Each plug is sparking. So what the hell else could it be?
Old 06-08-2008, 20:26   #2 (permalink)
Mitch
GRDriftGarage
Mitch's Avatar
Have you flooded it? Whip out the fuel pump fuse and try firing it up again, then refit it while it's running.
Old 06-08-2008, 20:32   #3 (permalink)
topi
KlutchKickKidz
topi's Avatar
I thought it might be flooded, so I took the plugs out and blowtorched the bores after leaving them 5 mins, cranked the engine over a couple times without the pump fuse - and reassembled. It did attempt to run when I put them back in.. but then died again.
When you turn it over, you can feel a slight BWOP from the exhaust, like its trying
Old 06-08-2008, 20:41   #4 (permalink)
alex_200sx
alex_200sx's Avatar
You got compression? Blocked intake, try taking the intercooler pipe off the throttle body, crank it over whilst spraying brake cleaner in there (watch out for backfire) if it coughs or changes note then you know the inlet isn't blocked
alex_200sx is offline   Reply With Quote
Old 06-08-2008, 20:47   #5 (permalink)
topi
KlutchKickKidz
topi's Avatar
Well I just took the pump fuse out and tried starting it like you said Mitch, and it did fire up for a little while.
Put the fuse back in, tried it and nothing. You can hear the Walbro whiring, but it's almost like it's flooding the engine?
Old 06-08-2008, 21:00   #6 (permalink)
alex_200sx
alex_200sx's Avatar
Ooh, i remember now, i had this with my CA18 (i know you've got a SR) but the injector wiring had shorted out and was permenantly spraying fuel into the bore, it did start but misfired, worth a shot. Is there any one plug that's wetter than the others?
Old 06-08-2008, 21:02   #7 (permalink)
2_stroke
2_stroke's Avatar
i know exactly what it is.....
....theres a midget stuck in there, he must have crawled up ur exhayst at night and that might be the coughing noise try a pack of lockets lol
2_stroke is offline   Reply With Quote
Old 06-08-2008, 21:05   #8 (permalink)
topi
KlutchKickKidz
topi's Avatar
Shut up Eddy lol.
Alex - all the plugs seemed equally wet :S argh
Old 06-08-2008, 21:11   #9 (permalink)
alex_200sx
alex_200sx's Avatar
Bugger, there goes my theory. I would personally try a compression test next. Cant think of anything else coz my brains gone to sleep, buy me a red bull and we might get it sorted lol
Old 06-08-2008, 21:17   #10 (permalink)
topi
KlutchKickKidz
topi's Avatar
Fuel pressure regulator maybe? How can I check?
Old 06-08-2008, 21:48   #11 (permalink)
topi
KlutchKickKidz
topi's Avatar
Sorted!
I re-red your advice Mitch, and put the fuse back in WHILE it was running. Stuttured a bit and them BWARP sorted!
Cheers for the assist
Old 06-08-2008, 21:51   #12 (permalink)
2_stroke
2_stroke's Avatar
bet the midget has a head ache now lol ..... well in maty
Old 06-08-2008, 22:16   #13 (permalink)
alex_200sx
alex_200sx's Avatar
Sorted, good one Mitch
Old 06-08-2008, 22:20   #14 (permalink)
Mitch
GRDriftGarage
Mitch's Avatar
Nice one You still still wanting the beads blastingness tomorrow mate?
Old 06-08-2008, 22:37   #15 (permalink)
topi
KlutchKickKidz
topi's Avatar
Possibly dude, I've got a feeling I might be able to aerosol them on actually, as it's a slightly wider tyre this time.
I'll take them to work and have a go at lunch time, as it's a little late now ha.
Old 06-08-2008, 22:38   #16 (permalink)
2_stroke
2_stroke's Avatar
just come dwn mine me mums pantenne stuff is mint 4 tyers and the nobours can get screwed lol
