Old 09-08-2008, 00:00   #1 (permalink)
boo_kong
boo_kong's Avatar
coilover measurements
I'v just got my coilovers like 3 days ago and everyday so far iv had to adjust them in one way or another.
Now' in the past i'v always measured the components of the coilovers,
the way i see it.... if your car is strate' making the coilovers the exact same should get it right first time, but noooo
my front drivers side seems to scrape a lil under tight left turns and when i had a look it's the under arch plastics....
Ok' well from there i did as everyone does and measured the wing to floor/ skurt to floor etc: etc:
From what i can see its about 15m out. 'drivers side front'
But again..... My car has a body kit so thos measurements are probably wrong anyways....
so what do i do? lol
where is the best place to measure from to make sure it is stop on?
boo_kong is offline   Reply With Quote
Old 09-08-2008, 02:45   #2 (permalink)
RyanH
I'd measure from the centre of the hub to the wheel arch, but someone else has probably got a better idea!
RyanH is offline   Reply With Quote
Old 09-08-2008, 09:23   #3 (permalink)
OrionRS
Thats what I did. To the highest point of the arch.
Old 09-08-2008, 10:42   #4 (permalink)
boo_kong
boo_kong's Avatar
Yea but what do you do when the arch's are part of a body kit and made of 'fiberglass'?
and not perfecly strat.
If they where stock metal ones then yea'
you see my problem? lol
i need options..... i even thought of measureing from the seal but getting a ruler/tape measure under there is not easy and wont get a precise measurement.
Heres the car
Old 09-08-2008, 11:05   #5 (permalink)
boo_kong
boo_kong's Avatar
well im off to have another try. :-)
Old 09-08-2008, 11:16   #6 (permalink)
OrionRS
Come down this way and we will have a look.
Old 09-08-2008, 11:19   #7 (permalink)
royal
S1- F.T break!
royal's Avatar
Maybe a silly suggestion but are you sure its not your dampening rate? ifs its soft on one side it'll be hitting the body more.
Old 09-08-2008, 19:06   #8 (permalink)
RyanH
Ah I see what you mean.
Maybe bumper off and measure from the front panel to the floor? You'd need a level ground though.
Park it on level ground and put a spirit level on the front panel?
Old 09-08-2008, 20:02   #9 (permalink)
OrionRS
I did mine earlier. Think I done it too much. NEED camber arms soon.
