Old 10-08-2008, 13:20   #1 (permalink)
OrionRS
S13 Suspension Advice
I was messing about with my coilovers yesterday and decided to set it really low. I took it out last night and it now handles crap. Now for the rear I know i need adjustable camber arms as the camber is right out. But I got a lot of understeer? The camber looks ok at the front. What could I do to prevent this?
The car is too low now, I will put it back to how it was for time being.
Old 10-08-2008, 13:27   #2 (permalink)
Vova
It might be because excessive lowering causes dynamic positive camber because the control arm changes its static position on a lowered car and pushes the wheel out during cornering creating positive camber. However this effect should be limited on coilovers as they keep body roll to a minimum.
When lowering, not only does camber change but also Toe and castor (the castor to a lesser extent), so you Toe might be quite out of alignment.
But how much have you lowered from stock?
Vova is offline   Reply With Quote
Old 10-08-2008, 13:40   #3 (permalink)
OrionRS
I will get a picture shortly.
The pic in my sig shows how it sat when I first fitted coilovers. It handled fine then.
TBH its too low for me. I knew it would put the geometry out but what could be done to solve it.
Old 10-08-2008, 18:09   #4 (permalink)
OrionRS
Here is how it is looking...
Old 11-08-2008, 09:22   #5 (permalink)
Vova
Well if you know how, you can check your alignment yourself, search the internet for DIY alignment to get a idea of how with strings and all. Or you can rob a bank and go a to a lignment place.
However, just raise it a bit and it'll most likely be fine.
Old 11-08-2008, 12:49   #6 (permalink)
Mach 0.185
Don't forget that if your camber has changed, the tyres may now be running on the edge of the tread, if you catch my .......drift......so you will have less grip until the tyres bed in to the new camber. Only when the tyres bed in will you really know whether the cornering / handling is better or worse.
Mach 0.185 is offline   Reply With Quote
Old 11-08-2008, 15:12   #7 (permalink)
OrionRS
Maybe that would explain why the rear is twitchy (hops about on a straight line) but what about the understeer on the front?
Old 11-08-2008, 15:20   #8 (permalink)
James
Lights out!
James's Avatar
Your toe settings will be out front and rear because you've lowered it. The camber won't make all that much difference to how it's driving, but the toe setting will make the car very twitchy and weird if it's miles out. If you've lowered the car more then about 50-60mm, your standard rear toe rods won't have enough adjustment to be able to compensate. Toe is easy enough to get set, most tyre and exhaust places will be able to do a quick check for fairly cheap.
Old 11-08-2008, 15:26   #9 (permalink)
OrionRS
Cheers.
For now I will just put it back up to sensible height.
As you say, it is very twitchy.
It must have put the front out by alot as on opposite lock it just slid. Didnt, grip at all.
Old 11-08-2008, 16:04   #10 (permalink)
RyanH
I had that problem when I had serious amounts of rear toe-in. I'm guessing it meant the back had serious amounts of grip, more so than the front.
RyanH is offline   Reply With Quote
Old 11-08-2008, 18:00   #11 (permalink)
OrionRS
Well I was having a bit of a play (donut) with opposite lock it just slid. Trying to push car forward as opposed to steering it.
