Old 11-08-2008, 02:39   #1 (permalink)
robbs
MANJI MAN
robbs's Avatar
volvo 940 ????
looking at volvo's again, if i buy another i wanna get the top bollox one which is the 2.3 turbo with the forged internals etc (hpt), what i need to know is how do i know which is which, what is the exact model im after ??? some say lpt so its easy to disregard them but im still confused as which are the decent ones also are the hpt's after a specific year ???
as i wanna do this
Originally Posted by TwinturboCH
Tuning - For a less than a grand you can have 300bhp
'Freddie' chip (volvo equivelent of a Horsham Developements type chip) £100
T5 (Cossie Green) injectors £250
Exhaust £150
Air filter £40
Boost guage £30
boost valve £30
Milling the flange to T3 fitment (i know someone who can do this for £90)
Cossie turbo
Run 20psi, get 300bhp
or does it not really matter if i get the lpt or hpt if im gonna change the turbo anyway is the engine still exactly the same???
also if anyone can point me in the direction of where to get all that stuff it would be great
Old 11-08-2008, 09:16   #2 (permalink)
Polo
Team Green!
Polo's Avatar
Im looking at them too, the LPT ones are still 165hp stock
Im looking around 1997 year for around £900 all the toys
I would have thoght the lpt comes with the same engine as the hpt.
Old 11-08-2008, 09:42   #3 (permalink)
Ali
Ali's Avatar
LPT's are more like 135bhp iirc, but makes no difference, just the boost levels with the LPT running 4psi and the HPT running 10psi making 165bhp. The sport then had more boost control stuff (think its called turbo plus or something) and that runs 14psi and makes 190ish. Afaik HPT & LPT are the same engine, the later engines having oil squirters and stronger rods and a better gearbox, can't remember what year they changed it but i'll try and find out
edit: mid 1994 change from 4 speed + overdrive to stronger M90 5 speed box
Also I would have thought same as Hudson's list but I think you can just use the T5 turbo, which is a mitsubishi 16T, think that just goes straight onto the standard manifold and can use standard downpipe, etc
edit again:
found out a bit more, only forged one's were really early, like 1985
the 850 T5 turbo is a 15G and will go straight on, should be good for about 270ish
The 850 T5-R, S70 and V70 T5's used the 16T but they changed something and only certain one's fit, not sure about that though, need to read up if you want to go that route
Get yourself on turbobricks, seems the best way to find out more
Im sure I read somewhere that a guy on turbobricks made 230bhp with standard everything other than the 16T
Ali is offline   Reply With Quote
Old 11-08-2008, 16:26   #4 (permalink)
robbs
MANJI MAN
robbs's Avatar
cheers fella's think i'd still rather get the hpt one so its more fun till i up the power, still wanna know the exact model name for the hpt's though if anyone know's ??? is it the SE ?
there also seems to be loads of saloon wentworths around for cheap anyone know what the max hp you can get from one of them for similer money ????
Old 11-08-2008, 17:18   #5 (permalink)
Mattis
Mattis's Avatar
Tere is a sticker on the timingbelt-cover with the engine code on. The HPT is called B230ft and the LPT is called B230fk. In case you didnt know
Mattis is offline   Reply With Quote
Old 11-08-2008, 21:10   #6 (permalink)
robbs
MANJI MAN
robbs's Avatar
not massively helpfull so far
hi newbie here looking for 940 info please - Turbobricks Forums
Old 11-08-2008, 22:18   #7 (permalink)
DriftLexus
BDC
DriftLexus's Avatar
seem like some arrogant bastards on there
Old 11-08-2008, 22:26   #8 (permalink)
robbs
MANJI MAN
robbs's Avatar
started a new thread and got some more info but im still confused as hell lol
940 2.3, whats needed to get near 300bhp ??? - Turbobricks Forums
Old 12-08-2008, 17:23   #9 (permalink)
Steve360
Right.. I'll try and clear a few things up...
No 940's had forged internals, only the B23ET from the early 80's did and they were in the 700 series.
With the turbo car's there were a few choices:
B200FT = 2.0 turbo, 155bhp at 7.5psi
Late 940's from around 1995 onwards had either the LPT or HPT:
B230FK = LPT, 135bhp at ~4psi
B230FT = HPT 165bhp at ~10psi
B230FT with Turbo+ = 190bhp at upto 14psi (strange vacuum solenoid controlled system that gives more boost at high rpm)
There are essentially no differences between the LPT and HPT in terms of hardware, it's only the actuator that is different. Get an MBC on either set to 12psi and that should be fine without pinking, giving 180-190bhp. I'd probably go for an LPT as it's less stressed from new.
Ofcourse as standard they're all fitted with the measly Mitsubishi 13c turbo... gives a nice fast spool but it's pathetically small. You can reclock some of the FWD Volvo turbos for RWD application, such as the 15g mentioned above but that's still fairly small. I'd go for a 16T or 19T from the later T5 cars. The 16T is similar to a T28 to give some comparison.
Pick of the bunch are cars after 1994, low pressure turbo 2.3's. The 5 speed gearbox is strong and far better than the 4 speed plus O/D. However it comes with a dual mass flywheel which is crap and heavy. But you can replace this with the earlier flywheel from a 4 speed plus O/D car assuming that car is equipped with the same management system (ignition reliefs in the flywheel differ) Bosch LH2.4. Might as well get one as late as you can.
I've been looking at 96-98 cars myself having bought Bolf's old Wentworth which was an awesome beater
What ya really want is a decent exhaust, 3" from the turbo back, bigger turbo, big ebay intercooler, injectors, Fred chips (Turbobricks), 3" AMM from a 960, and a better cam (the standard T cam sucks!)
My 945 turbo daily driver - Turbobricks Forums
Have a look at the spec of that to give you some idea
Steve360 is offline   Reply With Quote
Old 12-08-2008, 17:43   #10 (permalink)
robbs
MANJI MAN
robbs's Avatar
cheers steve very helpful mate, best answer i've got so far
sorry but what exactly do you mean by reclocking a turbo for rwd ??? and when you say a 3'' amm did you mean afm ??
Old 12-08-2008, 18:36   #11 (permalink)
Steve360
You have to rotate the turbo housings to line up with the RWD setup in the 940... there's a few threads on turbobricks if you have a search detailing this in depth. You have to make up a bracket for the wastegate but other than that all the cooling/oil lines line up.
The 15G is in, lots of pics! - Turbobricks Forums
A 15g is possibly a bit small for what you want, but the same would apply to the 16T and 19T turbos. I'm not sure what other turbos will fit but you will probably need to modify the manifold/downpipe if you choose something else.
If you're drifting it you'd be best welding the diff too - some cars did come with a locker (usually 2.0T Wentworths) but they only activate below 25mph, although I've heard you can modify the internals to change that! Although I might be teaching a granny to suck eggs there Saying that my old Wentworth went sideways all the bloody time with just an MBC set to 10psi and a bodged drilled airbox
Whilst your at it as you can see from that thread the manifold and housings can benefit from some porting!
AMM = Air Mass Meter, so yeah... AFM is the same thing I believe.
I'm probably on the hunt for a late 2.3 saloon myself... so if ya see any about that you're not interested in
