Old 11-08-2008, 20:07   #1 (permalink)
YashioFactory
YashioFactory's Avatar
smoking after decat - anything apart from the turbo seals?
just decated my Z32,
(2 cats as V6)
it smoked on boost after as soon as drove it.
so thaught turbo seals.
drove it OFF boost today to work and back (30 miles total)
then boosted it when coming from the gym, and no smoke???
is it possible that it was just flushing some old shit from outa the exhaust?
or isit 100% turbo seals and just didnt smoke just now?
Going to put the cats back on this weekend.
YashioFactory is offline   Reply With Quote
Old 11-08-2008, 20:16   #2 (permalink)
NORFY
NORFY's Avatar
some aftermarket exhaust parts have a very thin coating of anti rust stuff on them, could just be this burning off.
keep an eye on it for a week, sure it`ll be ok
Old 11-08-2008, 21:38   #3 (permalink)
YashioFactory
hmm..
its had kakimoto cat back exhaust on there since ive had the car (cuple months)
the decat pipes are second hand also.
yea il see how it behaves after a week?
perhaps its just some oil that was trapt/slodged just before the cats?
and is just being flusht out?
or it is the turbo seals
Old 11-08-2008, 22:02   #4 (permalink)
Danny_Boy
Send a message via MSN to Danny_Boy
Leave it on idle when warm for a bit, i decatted my old old S14a and it smoked wuite badly but i think the seals where a bit weak and the coplete lack of backpressure was pulling oil through the seals. Once the car was revved the smoke stopped. I ended up putting a differene exhaust on that had more back pressure and it cured it.
HTH
Danny_Boy is offline   Reply With Quote
Old 11-08-2008, 22:18   #5 (permalink)
YashioFactory
doesnt smoke on ildle.
not when rev it right out in neitrul.
only on boost, which isnt good
i decated on my S13 before, as soon as started up car, smoke pored out of it on idle, boost all the time.
the turbo was shagged, smoked with the standard exhaust & cat onit.
Blitz nur an decat really braught it out lol
anyway my Z isnt no where near as bad as my S13 was.
il see what its like on boost tomorrow, if still smokey the cats are off back on.
smokey car looks shit!
healthy car = happy me
Old 14-08-2008, 23:06   #6 (permalink)
YashioFactory
hmm...
still doing it, but not really bad.
think we all get the odd bit of smoke on boost?
long as theres oil in the car, and have an oil pressure gauge, ensure you sont burn off too much.
doesnt do on idle, or when revd out, so i think il just leave it a bit smokey now and again.
thanks anyway
Old 15-08-2008, 16:24   #7 (permalink)
Kenji
Kenji's Avatar
Send a message via MSN to Kenji
Blueish smoke on idle = turboseals
Blueish smoke on boost = valve stem seals
That's what I was told when my 1JZ was smoking (did that on idle).
I changed my turbo's recemntly to HKS T3G twinturbo's and no more smokeysmokey.
Kenji is offline   Reply With Quote
Old 15-08-2008, 16:28   #8 (permalink)
gandyRX
gandyRX's Avatar
could be some of the spray they use when they weld it, mine smoked for a abit (about 1hrr) after it was fitted but then went away, i did notice that there was a slight oily residue on the exhaust and on the inside of the packaging before i put it on
gandyRX is offline   Reply With Quote
Old 15-08-2008, 16:41   #9 (permalink)
NayAE86
NayAE86's Avatar
De-catted my old celica gt4 and it started smoking.....turbo oil seals went, one 2nd hand turbo later and viola no smoke
NayAE86 is offline   Reply With Quote
Old 15-08-2008, 23:10   #10 (permalink)
SxBoi
SxBoi's Avatar
Send a message via MSN to SxBoi
you sure its not overfueling causing the smoke?? check the injector connectors for corrosion very common problem which makes them overfuel
SxBoi is offline   Reply With Quote
Old 16-08-2008, 00:00   #11 (permalink)
Vova
The only reasones for (blue) smoke are:
1. Turbo seals -> allows oil into compressor which is venturied along into the cilinders.
2. Valve stem seals -> vacuum draws oil past the valve stem into the cilinder
3. Worn oil-piston-rings -> don't clear all the oil of the bore leaving it to be burned.
So its either one of those, good luck!
Ohw I forgot, there is a 4. Dwarfs at night opening your bonnet, taking out the plugs, spraying WD40 inside the cilinder, put everything back in, and feck off, videotape you driving away in the morning in confusion and laugh while sucking their trousers.
Vova is offline   Reply With Quote
Old 16-08-2008, 11:32   #12 (permalink)
YashioFactory
smoke isnt blue,
its grey.
only on boost, but not all the time?
reallly dont wana replace the turbos, as there are 2 of them, and its an engine out job on a 300zx.
as its not too bad, and only does it sometmes after hard driving,
ive come to the conclusion of leaving it. weighing the cats in for 100 quid.
i have GReddy oil pressure gauge, so can see when theres oil in there etc.
dont really give this car a hard driving often, more of a cruiser. but i like the power to be there! (3litre V6 TT)
thanks for posts, but its grey smoke no blue, and only after decat its noticible.
if was piston rings would have noticed it before i decated???
PS mods are:
Apexi intake, Kakimoto exhautst, decats.
Getting it chipt soon and then turning the boost up.
pics of my new car (Z32 TT)
Old 16-08-2008, 12:29   #13 (permalink)
royal
S1- F.T break!
royal's Avatar
Grey smoke is probably still the turbos, I think its something to do with if its burn't or not (? can't remember.). I had a kinked oil return hose on my Rex and it was smoking really badly grey until I sorted the hose.
Zeds smoking after decatting are pretty common. The shelf life of the turbo seals tends to be around 80-100,000 miles and decatting shows up weaknesses that were already there but not an issue due to the back pressure on the cats. If you stick the cats back on it'll probably be fine for ages.
Old 16-08-2008, 19:33   #14 (permalink)
YashioFactory
thanks,
what about if i leave them off?
itl get worse, eventually,
or will they just be gone completly after 2 weeks or something?
i havent weighed them in at the scrappys yet, just incase.
but probably will next week, as the smoke isnt too bad
Old 18-08-2008, 19:50   #15 (permalink)
Vova
I heard about a thing called a 'one wat valve trick' which is if I'm not mistaken, making a one-way valve for the oil-vapour-ventilation system so the engine can't suck oil vapour in but can expell it (one wat valve).
So you could try to route the cam breathers into a catch tank (or a soda bottle), blank off the PCV valve (you can unscrew it and put a 1/4" (iirc size) plumbing-plug in it, get it a a local hardware/plumbing appliances shop) and blank the intake-hose hole that is where the breather went into, a wheel nut usually fits. If this takes care of it, hooray!
Old 18-08-2008, 21:46   #16 (permalink)
YashioFactory
did this on my S13!!
workd a treat! (on idle, still smokes on boost)
i was thinkin how to do it on the Z, do you happen to know??
il post on the 300zx owners otherwise...
Old 26-08-2008, 11:24   #17 (permalink)
Supercharged
I also have a Zed TT (actually I bought it from UK) which runs with Kakimoto and decat pipes... It also smokes (grey/blue) when it's been running on idle for a few minutes... On boost there's no smoke at all. It's a common "problem" with the zed, so live with it, or put the cats back on...
Cheers,
Claus
Supercharged is offline   Reply With Quote
