Old 13-08-2008, 21:27   #1 (permalink)
nikkisixx69
nikkisixx69's Avatar
200sx nismo diff fitting question
im fitting a nismo 1.5way diff into my 200sx s13.
i have good mechanical knowledge(engine swaps,turbo rebuilds etc)
i have fitted diffs but never an aftermarket one.
ive been told i need to shim out the diff for it to fit correctly,
is this true or do i just need to bolt it in and set the backlash an shit? cheers guys!
by the way its an 89 200sx and the diff i got is an r200.
nikkisixx69 is offline   Reply With Quote
Old 14-08-2008, 16:42   #2 (permalink)
nikkisixx69
bump................
Old 17-08-2008, 17:20   #3 (permalink)
nikkisixx69
bump.....................
Old 17-08-2008, 17:47   #4 (permalink)
20vWill
20vWill's Avatar
I can do it properly for you.
It's a long and intricate process to do it properly, with a quite few special tools required and a lot of knowledge and experience.
If you want to just "bolt it in", I can sell you a new gearset for when it all goes wrong and needs to come back out again
Old 17-08-2008, 18:49   #5 (permalink)
nikkisixx69
thanks man but im all the way in ireland!!!
just wonderin does it need to be shimmed!!!
Old 18-08-2008, 01:55   #6 (permalink)
20vWill
20vWill's Avatar
Aaah OK lad, fair enough!
It will need shimming if the backlash is out of spec. Spec is 0.13-0.18mm, measured squarely to the drive side of a ring gear tooth.
I normally add equal shim stock to both sides to add preload to the carrier bearings. this makes for a stronger assembly under load.
