Old 28-08-2008, 12:22   #1 (permalink)
astra_coupe
having no luck
astra_coupe's Avatar
Send a message via MSN to astra_coupe
sr20 blocking turbo water lines
well ive searched and nothing really answered my questions im fitting an oil cooled turbo and the engine is out so what can i use to block the water outlet in the rad top hoses hard pipe (thingy) and in the block..
hope this makes sense cheers sim...
astra_coupe is offline   Reply With Quote
Old 28-08-2008, 12:30   #2 (permalink)
Karan
bolt with same thread and a copper washer should be fine
Karan is offline   Reply With Quote
Old 28-08-2008, 12:34   #3 (permalink)
astra_coupe
having no luck
any ideas on what the threads are?
Old 28-08-2008, 14:15   #4 (permalink)
Nebuchernezzer
Nebuchernezzer's Avatar
You have the engine out so it should be easy to work out.
If you don't have a thread gauge take the banjo bolt to a shop and get them to give you some bolts with the same thread.
As for the hose behind the head you can put bolt in that with a clamp or fit an SR20DE coolant line which lacks the turbo feed section.
Nebuchernezzer is offline   Reply With Quote
Old 28-08-2008, 15:34   #5 (permalink)
smokey
smokey's Avatar
Send a message via MSN to smokey
it's a M8x1.25 IIRC
smokey is offline   Reply With Quote
