Old 01-09-2008, 09:43   #1 (permalink)
Bunny
FAIL
Bunny's Avatar
Arch Rolling question
Right when rolling the arches does anyone cut the inner arch to get a good flair.
Bunny is offline   Reply With Quote
Old 01-09-2008, 10:39   #2 (permalink)
Cyruz
e-Dirty-6
Cyruz's Avatar
Send a message via MSN to Cyruz
Do you mean the inner lip where it bends at about 90 degree's inward. If so then yes lots of people do but it does make the arch a bit weaker, I'll be doing this as soon as I can be bothered.
Cyruz is offline   Reply With Quote
Old 01-09-2008, 10:42   #3 (permalink)
royal
S1- F.T break!
royal's Avatar
Sometimes removing the inner fold is enough to sort out the rubbing, and also its easy then to scaffold bar them
Old 01-09-2008, 10:47   #4 (permalink)
robbs
MANJI MAN
robbs's Avatar
yeah slingo cut the inner arch on his r32 rolled and flared then welded it back together, i wouldn't advise cutting the inner arch without welding it back though as it makes the arches weaker.
Old 01-09-2008, 10:57   #5 (permalink)
Bunny
FAIL
Bunny's Avatar
LOL @ Dave that's exactly what i've done. But removing the fold was definately not enough
Basically i've been using a bar to roll them. Drivers side flair is not bad but it's pulled the inner arch away from the outer arch. Made it easier for flaring lmao. But i'll need to cut it and weld it back on.
The other side didn't do this and i'm struggling to get it to flair. Hence the question. I'll cut it \ flair it and weld it back on
Old 01-09-2008, 10:58   #6 (permalink)
oli
-nightspirit-
oli's Avatar
not always the case, I've seen flare without removing that lip but folding it flat. depends on the car and the way the arches/bumpers sit in relation to each other.
oli is offline   Reply With Quote
Old 01-09-2008, 11:01   #7 (permalink)
Bunny
FAIL
Bunny's Avatar
Removing\folding the lip is not enough. The wheels were sticking out about 1.5"s from the outside of the arch.
Old 01-09-2008, 11:34   #8 (permalink)
oli
-nightspirit-
oli's Avatar
pics? and rim specs pls
Old 01-09-2008, 11:41   #9 (permalink)
Bunny
FAIL
Bunny's Avatar
I can't upload pics mate. Work internet doesn't allow it and i don't have internet at home at the moment.
It's an R33 skyline but after borring some of Stevo's ET12 wheels and seeing what they looked like i thought i'd chuck on some 25mm spacers lol and roll away.
Old 01-09-2008, 21:21   #10 (permalink)
Rayne
Rayne's Avatar
Bunny, think +30mm over fenders for the rims you are borrowing at the moment.
Also is +12 the offset of the rim without 25mm spacer? If so, that 25 mm spacer is going to make the rim have a -13 offset.
Heck with a spacer that big you might as well find wider rims.
Rayne is offline   Reply With Quote
Old 01-09-2008, 21:34   #11 (permalink)
griffo20022
BMW Driver...
griffo20022's Avatar
Interesting to see the mixed reviews, I'm hopefully gonna roll the arches on my E36 by the weekend. My initial plan was to just fold that inner lip flat rather than cut it out.
Old 01-09-2008, 21:55   #12 (permalink)
royal
S1- F.T break!
royal's Avatar
Don't you mean the other way around dude? A +12 offset and a 25mm spacer will bring the mounting point to +37mm inside of the rim center and give a wider track I think?
Old 01-09-2008, 23:01   #13 (permalink)
Cyruz
e-Dirty-6
Cyruz's Avatar
griffo, the arches are really tough on the 36, i folded mine and they really didn't want to move much after that, im going to cut them off and then flare them, might weld the lip back in if i can be bothered.
Don't fold the lip in if your going to cut, now I have to prise mine out again to cut it...!
Old 01-09-2008, 23:18   #14 (permalink)
NORFY
NORFY's Avatar
hammond rolled the arches on my 13 today with a bit of old exhaust, and they come out sweet. flattened the lip down first
Old 02-09-2008, 01:14   #15 (permalink)
Rayne
Rayne's Avatar
When I first started studying rims and tires I thought adding a spacer would bring the mounting point to higher number.
However an individual needs to realize that negative offset moves the rim closer to the fenders. Positive offset moves the rim closer to the suspension components.
Click here for a diagram. Looking at the diagram, if and when an individual adds a spacer in between the hub and the mounting pad of the wheel, the offset is effectively changed so that space can be added between a part being rubbed and the tire or the rim face.
Now there is a way to make an offset of a rim higher than it was originally. However to do that individual is looking at modifying the rim itself.
Old 02-09-2008, 01:35   #16 (permalink)
superclarkey
______________
well a stock 200sx S14 with 9.5J ET12 needs a bloody good flair to fit 265 rubber under the back but if your running gay strech then you'll get away with it, adding a 25mm spacer is pointless and lets face it the rollcenter is already going to be trashed when you've cut your springs down to the chassis rails
I wouldn't bother and you will be hanging out of your 50mm overfenders with them spacers
Old 02-09-2008, 09:10   #17 (permalink)
Bunny
FAIL
Bunny's Avatar
I don't have an S14 and i certainly am not running on Cut springs.
The ET12's are not on the car anymore they were borrowed for a trial fit.
i've got gay offset et38 wheels hence the spacers.
Yes i rolled the lip first. Yes i've done a flair on 1 side so far because it needs it. When i get time i'll finish the other side and weld the inner arches back.
Old 02-09-2008, 10:43   #18 (permalink)
royal
S1- F.T break!
royal's Avatar
I wondered why I was getting confused. Your diagram doesn't work but I looked up some sites and turns out the all singing, all dancing fancy arse suspension book I've got (how to make your car handle, fred puhn) has it the other way round to everywhere else! God knows why, or I'm just being a bone head?
Old 02-09-2008, 11:15   #19 (permalink)
Rayne
Rayne's Avatar
As long as you understand that spacers actually lower the offset rather than increase it. You know all that you need to know where spacers are concerned.
