Old 01-09-2008, 20:55   #1 (permalink)
Ed
Ed's Avatar
S13, more left lock than right??
I've got about a quarter turn more left lock than I have right, is this normal??
I dont recall any of my previous S13's doing this
If its not normal, what do I need to be checking?
Ta,
Ed
Ed is offline   Reply With Quote
Old 01-09-2008, 21:08   #2 (permalink)
royal
S1- F.T break!
royal's Avatar
Are the wheels straight when the steering wheel is centralised?
If so then its almost like there is a tierod-spacer / uprated tierod with spacer on only one side. Perhaps the previous owner broke one side and replaced it with a standard? although the tein ones need the accompanying tie rod ends because they are more beefy than the oem ones.
Old 01-09-2008, 21:15   #3 (permalink)
Ed
Ed's Avatar
I broke & replaced the passenger side track rod after 2 weeks of owning it Should I replace both of them??
Dude, your sig is brilliantly scaring/funny
Old 01-09-2008, 21:37   #4 (permalink)
royal
S1- F.T break!
royal's Avatar
Haha, that'll probably be it then you just need to make each side the same. If you've replaced one side with teins then you'll need to do the other side to match it because they have built in spacers.
Old 01-09-2008, 21:42   #5 (permalink)
Andy_f
I <3 BDC!
Andy_f's Avatar
FYI, my teins didn't have built in spacers. I wasn't aware that they did. My guess is that it has been aligned over time just by adjusting one side of the steering assembly rather than centralising them both. IE, if you took both steering arms off, one of them would be shorter than the other, meaning the end of the steering arm would be hitting the end of the rack sooner than on the other side, thus giving you less lock.
You could sort it yourself though I think, take both arms off, measure, get an average of the two lengths, set both arms at this length, replace and voila, steering should be perfectly central. Either that, or something is bent.
Old 01-09-2008, 21:45   #6 (permalink)
Ed
Ed's Avatar
Another job for the weekend then, here was me hoping it was normal
Old 01-09-2008, 21:59   #7 (permalink)
Mitch
GRDriftGarage
Mitch's Avatar
They don't, Dave. They have a slip on thick washer but aren't built in.
BTW-'Chelle says your sig pic looks special, but I think you look lovely.
Old 01-09-2008, 22:43   #8 (permalink)
royal
S1- F.T break!
royal's Avatar
Ahhh yep, was thinking of my uras ones for the rex. Should have remember because I snapped one last month and stuck the spacer onto an oem one
My mum says I'm luvely and special too
