Old 01-09-2008, 23:36   #1 (permalink)
dj_snathe
dj_snathe's Avatar
Unhappy R32 manual conversion help :(
I've fitted my RB20DET manual box into my R32 non-turbo (RB20E) and found that the gearbox crossmember doesn't line up with the mounting points on the shell. Instead it sits between 1.5 & 2 inches too far forward! Do I need a different crossmember? I've tried both the auto and manual ones and they're both the same
dj_snathe is offline   Reply With Quote
Old 01-09-2008, 23:56   #2 (permalink)
superclarkey
______________
auto R32 shells are differnet to manual shells
I think from memory a R33 crossmember will fit, i have one of them also
Clarkey.
Old 02-09-2008, 00:10   #3 (permalink)
dj_snathe
dj_snathe's Avatar
Fookin hell clarkey, you must be my guardian angel today! lol
I might have a 33 one somewhere in the tip I call a garage, but will be greatful of yours if I haven't
Are you free tomorrow evening for me to collect the prop?
Old 02-09-2008, 00:21   #4 (permalink)
Mark_McQ
Mark_McQ's Avatar
I know the auto has a wider transmission tunnel than the manual, so that may account for the holes not lining up.
Mark_McQ is offline   Reply With Quote
Old 02-09-2008, 00:32   #5 (permalink)
superclarkey
______________
yeah i'll be about...
I know the R32 Shells are different from Manual to auto, an R32 Auto shell with take an R33 box without modifications, were as you've found out the R32 manual is too short and to narrow.
I've never tried fitting an R33 mount to an R32 box to solve this problem as i normal just fit an R33 box outright.
But i'm sure the R33 mounting i have will be far closer and less modification requied. I would happlying modify the mount for you if you so need it.
Clarkey.
Old 02-09-2008, 01:01   #6 (permalink)
Rayne
Rayne's Avatar
Find a crossmember that goes with a manual gearbox.
The shell is the same regardless of the gearbox. The difference is in the crossmember.
Rayne is offline   Reply With Quote
Old 02-09-2008, 01:13   #7 (permalink)
superclarkey
______________
Is that a fact.
Old 02-09-2008, 02:22   #8 (permalink)
Rayne
Rayne's Avatar
Yes, it is a fact. I used to have a crossmember for an auto gear box and a manual gear box. The crossmembers were noticibly different.
Go compare the crossmember from an vehicle with an auto gear box with the crossmember from the same model but with a manual gear box.
Old 02-09-2008, 02:26   #9 (permalink)
superclarkey
______________
So, why is it may i ask when you fit a R33 GTS-T (large casing box) into a Manual car you have to knock back the tunnel a little to get it to clear, and you have to cut and reweld the standard mount... where a Auto shell it drops it with plenty of room and bolts strait up...
Just interested to know were i've gone wrong these last 8 years...
Old 02-09-2008, 02:44   #10 (permalink)
Rayne
Rayne's Avatar
If you are talking about putting an R33 gearbox into an R32. Yeah the shells are different. Those two verhicles are different. Plus the engines are different, which in turn makes the bellhousing different.
If you are talking about putting an R33 gearbox into an R33, the shells are the same. The crossmembers are going to be different between the same model car.
Here in the states several people swap bell housing to make an S14 gearbox fit in an S13.
But hey, I am still new to the methods used in Europe so, I can still be wrong.
Old 02-09-2008, 03:00   #11 (permalink)
superclarkey
______________
First off, i'm talking about only the R32 skyline.. I'm not mistaking a R33, i understand the model differneces
Talking only about the HCR32 shell.
Regardless of engine, RB20DE/RB20DET/RB25DE in the HCR32 the engine finishes in the same place, the crossmembers look the same and will messure the same but the mounting points on the shell are 20mm futher back, 100% on that one
End of the day i know there is a differnece because i actually do the conversions, if you only ever read about it on the interenet then you will only know what they tell you, and tbh alot of people become experts on something they really don't know much about.
So you now know that the Shells i.e R32 auto and R32 manual HCR32 shells are different, as are the HNR32 shells (GTS-4), regardless of if all people tell you that the mounting points are different, its a bit more then that, i'm more then happy to note down the dimentions tomorrow and post them as i have both cars in my workshop.
We also swap the S13 gearbox's into the RB bellhousings here and use them on the RB20/25/26 de/det/dett engines. (bearing inmind they don't last long on some )
Sorry to be blunt but people will search on this info and it needs to be factual.
Clarkey.
p.s it is the same with the manual to auto R32 box's (i.e auto R32 gearbox converting to manual R32 gearbox)
Old 02-09-2008, 03:22   #12 (permalink)
Rayne
Rayne's Avatar
No need to post any more information. As I stated in my last post, I can still be wrong. I am glad that there are many individuals with experience with various vehicles.
I for one am familiar with the S13 and S14 more than I am with the Skylines.
I did forget that there were different models of skylines within the same year. (Four Door and Two door) Thank you for reminding me.
Old 02-09-2008, 09:51   #13 (permalink)
gaz_moose
.MTM.
there is a crossmember that bolts straight up OEM style
you just have to use your noggin to work out which one
Old 02-09-2008, 10:38   #14 (permalink)
superclarkey
______________
I think its the S14 oen that bolts up, but not 100% sure
Old 02-09-2008, 10:56   #15 (permalink)
Bon Bon
What Pizza?
Bon Bon's Avatar
Can't remember which crossmember I had on my 32 but I remember Julian pulling faces at it.
Old 02-09-2008, 12:14   #16 (permalink)
dj_snathe
dj_snathe's Avatar
YAY I've just found a S13 crossmember that looks like it'll fit
Clarkey, can you pm me your number so I can arrange collecting the prop tonight? Cheers dude
Old 02-09-2008, 12:22   #17 (permalink)
superclarkey
______________
yeah sure mate on the way now.
Old 02-09-2008, 13:41   #18 (permalink)
gaz_moose
.MTM.
it was julian that told me
the s13 one doesent work as i have tried it.
Old 02-09-2008, 13:54   #19 (permalink)
superclarkey
______________
depends also on what subframe you use, as R32 and R33 subframes throw the engine into differnet positions
Old 02-09-2008, 16:44   #20 (permalink)
dj_snathe
dj_snathe's Avatar
The S13 manual gearbox crossmember looks identical to the R32 one, but is back to front. This should line the 4 mounting holes up with the captive nuts in the chassis nicely I'll keep you posted as i've yet to get the car back onto the ramp and offer it up into position.
