Old 02-10-2008, 11:43   #41 (permalink)
JTHM
JTHM's Avatar
Cheers buddy. that would be awesome!
I'll keep looking elsewhere for it aswell though.
Thank you
J
JTHM is online now   Reply With Quote
Old 03-10-2008, 00:48   #42 (permalink)
mixmasterspike
mixmasterspike's Avatar
Originally Posted by jamespayne5 View Post
Edit.... I've just seen your boost pipes are held together with cable ties!
I'll bet money that you have a massive boost leak from there! Get some jubilee clips on there! I'm sure that'll solve your problem!
oh my...cable ties
ive never seen that before in all my days
I know they are useful but this is a little worrying
I'd say if i hadn't seen them then check plugs, plug gap, boost leak, afm needs cleaning, coilpacks.
mixmasterspike is offline   Reply With Quote
Old 03-10-2008, 00:49   #43 (permalink)
mixmasterspike
Originally Posted by Mitch View Post
If that doesn't work, try the lambda sensor
if its as high up in the rpm range as 2.5-3k will this be true, i tought it only comes into effect on low revs and idle
Old 03-10-2008, 00:50   #44 (permalink)
mixmasterspike
Originally Posted by wheresmejumper View Post
to me that just looks like rubber protecting the intercooler cold pipe from rubbing off the cut battery tray....did the same in my own car....as in really,who the fcuk would be stupid enuff to cable tie a boost pipe??
it all makes sense now, well done inspectah
Old 03-10-2008, 00:57   #45 (permalink)
mixmasterspike
My intercooler cracked on my s14a....caused misfire at high revs...i.e on boost....you could easily tell on mine but it may not be the case with yours, pressure test the system....failing that compression test....however you may want to do that anyway for peace of mind
Old 03-10-2008, 07:40   #46 (permalink)
Mitch
GRDriftGarage
Mitch's Avatar
He's already said it was the lambda sensor (as I mentioned a couple of weeks back ) and that is the most blatent post whoring I've seen in a while. What are you waiting to sell?
Old 04-10-2008, 21:08   #47 (permalink)
JTHM
JTHM's Avatar
LOL just what I was thinking. Was wondering why he used more than one post.
Back on topic.
We've had a measure of success:
Lambda sensor was replaced (with a new item from an escort cosworth).
The misfire went away and came back, now at 3500>4000rpm. it is however, intermittent.
I did manage to get it home from Newcastle to Edinburgh (just couldn't floor it).
SXOC has suggested the AMF wiring so am looking at that tomorrow.
Cheers for all your help.
Jamie
