16-09-2008, 20:27
| tail slider Join Date: Jul 2007 Location: Loughborough
| DW Wasted spark RB25DET / PowerFC Please help, am at the end of my teather and i've booked the car in for mapping on friday after a 8month build ![]() Got a DW wasted spark kit, that afaik was setup correctly so shouldn't be a problem. Do you have to change any settings on the PowerFC for the different ignition setup like you do with the AFM/Injectors?? My mate is a mechanic and he's been over to check it out and says all is good with way i've done it but he can't make sense of the Ignition setup on the car, i'm not technical but he says a wasted spark kit should Pulse not be constant but he's getting a constant live feed when he tests it Can't get the car to spark up, so its definately an ignition problem, the igntion amp appears to be okay PLEEEEZE HELP ![]() |
16-09-2008, 20:38
| #2 (permalink) | |
| Just looked back at an old post of mine How do i wire this up to my car if it was for a Series2 car then ? my brain is fried from all the work i've done on it the last few days ![]() Quote:
17-09-2008, 15:20
| #3 (permalink) |
| please can someone help, i've PMd two people that should know about this, and posted it up on a few of the owners clubs as well and i'm really starting to get desperate, i don't want to back out of the spot i've got booked at the tuners on friday as they'll get pissed off with me for cancelling at the last minute They've probabyl turned down work to fit me in There are a couple of loose wires there is no ground loop , where do i take the ground wires from on a 2 wire plug??? |
17-09-2008, 15:50
| #4 (permalink) |
| Lights out! ![]() ![]() ![]() Join Date: Jul 2004 Location: Birmingham UK
| Hi Ian, sorry for the delay, Phil's out today and Bon's in the workshop so we're a little stretched ![]() So....... a few facts/questions so we can get you sorted: You don't need to change anything in the powerFC to run wasted spark, the act of joining the wires for the cylinder pairs (1&6, 2&5, 3&4) together will do this. If your mechanic friend has tested for a live 12v+ feed at the coil, he will find one that is on constantly when the ignition is on, that's correct and as it should be. Most coils of this type have a permanent live feed to them, then they fire each coil by switching the earth rather than the 12v+ Are you seeing no sparks at all? and is this the same for all cylinders? So you have it wired in with an ignition amplifier now? Do you have any pictures that show how you've done it so we can take a look? Have you got the plug leads going onto the coil using the numbers stamped into the plastic housing? This way is wrong and that's a fairly common mistake. Have you earthed any black wires? It's common for one of the black wires to also be connected to the cyl 1 trigger wire and this can cause problems with cyl 1&6 as this means the coil is always on rather than pulsing when it's needed. |
17-09-2008, 16:03
| #7 (permalink) |
| i've got 3 white wires joined together, they all go to a 2 pin plug and there is another wire that was joined to it that looks like its been cut off, also there are two more wires coming off the white wire that look like they've been cut off at the same point |
17-09-2008, 16:22
| #10 (permalink) |
| That doesn't sound quite right to me..... Hopefully this picture helps: Think of the coilpack as 3 seperate coils joined together. I've coloured each one in a different colour to illustrate the 3 distinct parts. It doesn't really matter exactly which cylinders are joined to which sections of the coil, as long as each pair 1&6, 2&5, 3&4 is on the same coloured (in my diagram) section of the coil and your pink wires into the ignitor pack go to the corresponding coil section ![]() |
17-09-2008, 16:29
| #11 (permalink) |
| taking it all apart and restarting isn't a problem, i'll do that if its wrong, its just working out where there wires go as i've only got a 2 pin plug ... that diagram of the 3 pin plug is just confusing the matter further. ...is there a diagram of the setup with a 2 pin plug? i think that should sort it out in my head where it should be |
17-09-2008, 23:46
| #17 (permalink) |
| ______________ ![]() Join Date: Aug 2004
| ![]() I'm talking about that metal bracket on the coilpack, it is ground triggered, and you have a bit of metal that is bolted to ground (the chassis), i could see it ending in tears ![]() personaly i would use a plastic to mount it, not metal. or at least rubber sheld it. clarkey. |
