Old 17-09-2008, 14:48   #1 (permalink)
SILBEAM81
SILBEAM81's Avatar
Sr20
CAN ANY BODY TELL ME IF THE SR20DET HAS THE SAME CRANK AS ANY OF THE REST OFF SR20 RANGE eg PRIMERA GT WITH SR20DE
SILBEAM81 is offline   Reply With Quote
Old 17-09-2008, 18:14   #2 (permalink)
wheresmejumper
Banned
99% sure all sr20's use the same crank.
wheresmejumper is offline   Reply With Quote
Old 17-09-2008, 19:31   #3 (permalink)
jamespayne5
jamespayne5's Avatar
They're not the same for all sr20's
jamespayne5 is offline   Reply With Quote
Old 17-09-2008, 20:46   #4 (permalink)
PhatBob
Ken Block???
PhatBob's Avatar
I am pretty sure the FWD is different to the RWD.
The place I'd go to find out for sure is here:SR20 Forum - The essential resource for all things Nissan SR20 on the Web - http://www.sr20forum.com they seem to know a huge amount on engine specifics and interchangeability.
Old 17-09-2008, 21:51   #5 (permalink)
f.y.e
the rear wheel sr engines found in the s-bodys are all indentical (redtop, blacktop straight cam non vvt sr20det and the vvt sr20 engines) but the cranks in the sr found in pulsar (4wd) and bluebirds (fwd) differ significantly
f.y.e is offline   Reply With Quote
Old 17-09-2008, 21:57   #6 (permalink)
SILBEAM81
SILBEAM81's Avatar
in what way please.....
Old 17-09-2008, 22:12   #7 (permalink)
wheresmejumper
Banned
my bad....didnt read the question properly
Old 18-09-2008, 01:02   #8 (permalink)
f.y.e
id assume the ends of the cranks would be different to sit flush in its designated engine type housing
Old 18-09-2008, 01:50   #9 (permalink)
superclarkey
______________
i thought fwd SR20DE were distributors not CAS?
I know my RWD SR20DE was a distributor.
clarkey
Old 18-09-2008, 07:41   #10 (permalink)
SteveC200
talent bypass
SteveC200's Avatar
Apart from the head design, inlet manifold and plenum, oil galleries, etc.
Old 18-09-2008, 08:11   #11 (permalink)
PhatBob
Ken Block???
PhatBob's Avatar
clarkey
Its the exact same bolt and mounting pattern as the CAS - I delighted the assembled crowds with my slight of hand and dexterous doings when I swapped one with the other on my pointless engine
Old 18-09-2008, 08:21   #12 (permalink)
PhatBob
Ken Block???
PhatBob's Avatar
This is true, the SR20 is the engine model number, there are different versions/combinations:
Taken from SR20forum.com
1N5 V1 - SR16VE
1N5 V2 - SR20VE
5J -
51N -
52F - Larger Exhaust Valves Silvia engine
53C - JDM Pulsar GTi-R. 8.3:1 T28 Turbo Low Imp. 444cc Injectors Larger Top Mount Intercooler Larger Oil Cooler Solid Lifters Ind. TB's Oil Squirters
53J 2L- Flat Pistons, highport, egrless and gold/black Valve cover (*)
53J 2R - Normal pistons, highport, egrless and gold/black Valve cover
53J 4R - found in South African Nissan Sentra's and Sabre's. Silver valve cover and 10:1 compression.
53J 7R. Gold Valve cover with black strip down middle, egr-less, tubulor exhaust, highport
53J V1 - USDM Black Channel Valve Cover Highport 9.5:1 1990-92 Red Injectors EGR OBD-1
53J V2 - 1R USDM Silver Valve Cover Highport 9.5:1 Red Injectors EGR OBD-1 1993 RIBS
53J V3 - 5R JDM Ribs on head Silver Valve Cover Red Injectors Mitsubu Alt. tubular ex. manifold 1/1 in circle and /5 in circle on head beside 53J
53J V4 - JDM Black Channel valve cover
53J V5 - JDM Silver Valve Cover No Ribs
53J V6 - BlueBird SR20DET 8.5:1 sodium filled valves 7mm stem Oil Squirters T25 Turbo High Imp. 370cc Injectors Top Mount Intercooler Oil Cooler Hydraulic Lifters Single TB
53J V7 - JDM Black Channel valve cover tubular ex. manifold 10:1
53J V8 - 2L W11 Avenir 8.5:1 silver valve cover Ribs 370cc purple injectors T25 ball bearing turbo Big TPS No EGR Mitsu altenator High port Internal coil OBD-I Stock oil catch can steel pipe has a built in restrictor.........the one the runs from the valve cover forward then behind the distributor to the stock catch can. same BOV/CBV as teh 1stGen DSM
53J V9 - W10 weaker BOV then the W11 Non ball bearing turbo 8.5:1
53J V10 - 3L 10:1 JDM bare aluminum cover w/ black in the middle No Ribs under the coil there is a circle with a line through it and a small number 7
53J V11 - 2R I think this is a W10 BlueBird SR20DET 8.5:1 sodium filled valves 7mm stem Oil Squirters T25 Turbo High Imp. 370cc Injectors Top Mount Intercooler Oil Cooler Hydraulic Lifters Single TB Red V/C black channel
53J V12 - 3L JDM Ribbed head, All silver valve cover, either a 6 or 9 and a 1 in circles under the coil.
53J V13 - 8R JDM with an 8 in a circle behind the coil bare aluminum vc tubular header external coil and egrless of course highport ribs on the side of head
53J V14 - 8L USDM Ribs 93 NX2000 All Silver Valve cover 9.5:1
54C - N14 Pulsar DET
54D -
58Y - SR18DE JDM highport.
64J - SR18DE SR18Di JDM lowport.
65J - 2R 2J2 10:1 JDM Silver valve cover
78E - BlueBird SR20DET (53J Head) Larger Exhaust Valves
79E - Larger Exhaust Valves
89H - SR20DE Silver Valve Cover U.K. '94 SLX P10 lowport No ribs 10.0:1.
89J - SR20DE Red Valve Cover UK lowport sodium filled valves 10:1 Gray 259cc Injectors .
94Y V1 - 3L SR20DE US lowport 9.5:1 OBD-1 1994
94Y V2 - SR20DE US lowport 9.5:1 OBD-2 1995-99
96J - 1R UK Redtop 10:1 Highport (UK 101 1R 96J head)Gray 259cc Injectors Mitsubu Alt. sodium filled valves
Unknown - USDM B15 Roller Motor Nonpainted VC 9.5:1 OBD-2
Unknown V1 - AUTECH 11.5:1 175hp for Lucino Nonpainted VC
Unknown V2 - AUTECH 11.5:1 180hp for Primera Nonpainted VC
Unknown - 53J 4R, JDM 53J 3L, 53J 1R McRib USDM, 53J 4J???, 53J 4L
Old 18-09-2008, 09:10   #13 (permalink)
Rayne
Rayne's Avatar
You are correct, the FWD SR20 is different than the RWD SR20 and there are parts that are interchangible between the two.
The biggest difference between the to engines is the location of the distrubutor. If an individual wanted to take the time to modify the firewall he/she could mount a fwd SR20 to the RWD transmission. Considering the number of SR20 engines still around it is easier to get a RWD engine.
Rayne is offline   Reply With Quote
Old 18-09-2008, 09:51   #14 (permalink)
superclarkey
______________
cool never said they wouldn't swap over, just ment they are different out of the factory, i know you can put the cas on them as it has the same nose drive and bolt patten.
But i have never done it as no one pays for them engines to be tuned.
is there not a problem when putting FWD engine into a rwd car with oil retrun from the head problems ?
Old 18-09-2008, 11:32   #15 (permalink)
PhatBob
Ken Block???
PhatBob's Avatar
Not in drifting they don't, but I'm told that the Almera and Sunny's are used in Rallying where turbos carry a penalty, doing anything to a DE on a driftcar is pointless as for next to no money you can drop a DET in.
Oil return, the distributor mounting and also the issue of the blocks engine mounting points. The SR20DE in the BTCC cars had external oil return pipes, although I'm not 100% sure if this was because of poor return, or the fact it was mounted at such an extreme angle.
I'm on the lookout for a SR20VE head, which I'd run with a crank trigger.
But to stop this becoming a thread hijack:
SILBEAM81 - I'd bet on the safe side and leave the FWD stuff alone, there doesnt seem to be much difference in the DE and DET blocks of the RWD engines, and there are plenty of them about.
What were you hoping to use a FWD crank/engine for?
Rob
Old 18-09-2008, 11:34   #16 (permalink)
superclarkey
______________
thanx bob, thats what i heard also, but not seening it for myself didn't want to guess
Thanx.
Old 19-09-2008, 21:42   #17 (permalink)
SILBEAM81
SILBEAM81's Avatar
i have a sr20de crank here with std big ends and mains so just thinking of selling it just needed to know if it fit rwd block or fwd only as the throw is the same
Old 24-09-2008, 13:34   #18 (permalink)
SILBEAM81
SILBEAM81's Avatar
right i'v dun alot of reading on sr20 forum and the sr20 has three cranks that i'v found a non vvt a vvt and the one in a gtir can anybody conferm this ...thanks
