Old 18-09-2008, 18:05   #1 (permalink)
samcoz
Question s13 t3 advise needed
im looking for any imformation i can get on t3 conversions for an s13 ca18det? i need to know what car you use the t3 from an what has to be modified in order to fit it and is it worth doing in the first place?
samcoz is offline   Reply With Quote
Old 18-09-2008, 22:20   #2 (permalink)
f.y.e
from my past experiance dude when i was about to do a t3 conversion to my sr engine in the s13, i was going to have to modify the elbow as they are diff compared to the t25/28 standard s body elbows and had to find a top mount manifold and do a bit of modifing to make it fit, the turbo lines need to be blocked as some are only oil cooled so i went down the garret way as it was a oem fitment, t3 would produce lag and are a better upgrade for a rb engines then a ca or sr
f.y.e is offline   Reply With Quote
Old 24-09-2008, 18:21   #3 (permalink)
samcoz
cheers mate think ill give it a miss t28 then.
Old 24-09-2008, 18:28   #4 (permalink)
wheresmejumper
Banned
there are still some big power laggy t2 turbos that will fit straight,if thats what your after....gt2876r, or the t2 internally gated gt3071r
wheresmejumper is offline   Reply With Quote
