23-09-2008, 17:13
| Go!Go!Auto Join Date: Aug 2004 Location: Cornwall
| Trigger configuration on SR20 CAS ? I need to know what the toothed configuration of the SR CAS senor is. Ideally how many teeth and missing teeth please. EDIT, just found it... the answer is lots. Last edited by Mighty_Mini : 23-09-2008 at 17:21. |
24-09-2008, 16:35
| #4 (permalink) | |
any idea where i might be able to purchase a 36-1 toothed wheel for the nissan cas? | |
30-11-2008, 00:53
| #6 (permalink) |
| gripper Join Date: Jan 2008
| help they are 360 small on the edge, and 4 different sizes in the middle, i dont think you can use other cas with the standard ecu, but inside your cas fits cas from 4g63 or somethink like that, from mitsubishi eclipse for example, there are 2 models one of them is 4/2 cas with optical sensor like nissans cas, this one fits inside, and autronic trigger disc fits, depends what you want to do ... i use megasquirt with autronic trigger disc ... if needed i can send to UK for something like 30pounds plus post taxes ... this is the prise from the local autronic dealer in bulgaria ... they make autronic here on some CNC machines thats why its more cheap than from australian dealers and USA ones |
