Old 24-09-2008, 18:32   #1 (permalink)
s12 silvia
s12 silvia's Avatar
think my idal controll valve needs cleaning?
on my skyline r33 when its first start it in the morning from cold its ok until i set off and it drives fine but if i stop at say a junction it reves itself as if i was pumping the throttal? once its to perfect tempreture its fine a freind of mine thinks i need to clean the idal controll valve?
where is the idal controll valve and do i just soak it in petrol?
many thanks
matt
s12 silvia is offline   Reply With Quote
Old 24-09-2008, 18:42   #2 (permalink)
wheresmejumper
Banned
onto the inland manifold....spray it with carb and choke cleaner
wheresmejumper is offline   Reply With Quote
Old 24-09-2008, 19:00   #3 (permalink)
s12 silvia
s12 silvia's Avatar
so you think thats what could cause the reving???
Old 24-09-2008, 19:03   #4 (permalink)
DoriDave
Unroadworthy
DoriDave's Avatar
Ours does it every now and again. Doesn't cause any problems though, I just blip the throttle and it settles down again.
DoriDave is offline   Reply With Quote
