Old 26-09-2008, 20:29   #1 (permalink)
shirunai
shirunai's Avatar
Aftermarket flywheel for a rs13 ca18det question
Is it worth it ? my engine has died, my clutch is almost dead 0.1mm left and my flywheel need skimming, I was thinking of Driftworks ca18det flywheel is it worth it ? I have stage3 and I clutchkick alot really due to small circuits here in Sweden (I drift at bigger circuits aswell). Will I feel any response at all ? Will it be a improvement?
I am not a rookie but no pro either not even near has almost none twindrifting experiance but doing third gear atleast, question is will I feel any difference in my skill level or should I save some money?
shirunai is offline   Reply With Quote
Old 04-10-2008, 20:21   #2 (permalink)
shirunai
shirunai's Avatar
bumpage
Old 04-10-2008, 21:30   #3 (permalink)
Daniel san
Send a message via MSN to Daniel san
Yeah, as you should be using a paddle clutch for drifting or generally abusing the car with clutch kicks etc and the stock fw gets chewed up easily with that kind of use from a paddle clutch, so a new fw is essential.
Daniel san is offline   Reply With Quote
