Old 03-10-2008, 15:14   #1 (permalink)
MR.T
DRIFT RETARDED
MR.T's Avatar
200sx warning lights??????
i noticed a red box with pipe/ lines and wave line s above the box after i stopped i see the cat sensor from the old cat had been scraping the floor
also twice today while driving my revs dropped to 1k rpm and wouldn't car wouldn't move or rev so after sitting for a minute i tried revin it again and all was fine
these connected?
MR.T is online now   Reply With Quote
Old 04-10-2008, 17:51   #2 (permalink)
MR.T
DRIFT RETARDED
MR.T's Avatar
these connected?
can i cut out the sensor? its the cat over heat sensor
Old 04-10-2008, 18:08   #3 (permalink)
MR.T
DRIFT RETARDED
MR.T's Avatar
need help
Old 04-10-2008, 18:10   #4 (permalink)
Jord
Origin x Skay
Jord's Avatar
Only time I've ever seen that light on mine was 5th gear WOT from low down revs during mapping. Knock reading shot right up at the same time too so I think they are related.
Old 04-10-2008, 18:13   #5 (permalink)
sx-si
sounds like somthing for sxoc lmao but there will still be 20pages of bs
sx-si is offline   Reply With Quote
Old 04-10-2008, 18:16   #6 (permalink)
MR.T
DRIFT RETARDED
MR.T's Avatar
the sensor is damaged and now its rapped in duct taped hanging
it has always over fuelled
dunno if afm has gone, but the cutting out only started when the warning light came on
Old 04-10-2008, 18:26   #7 (permalink)
LiGhTnInG
Doricomotion
LiGhTnInG's Avatar
Do a loopback on the circuit and retest mr Midnight-D
Old 04-10-2008, 18:51   #8 (permalink)
MR.T
DRIFT RETARDED
MR.T's Avatar
im confused i asked on the sxoc and was told to cut the sensor off.... it was snapped anyway so i took the sensor off and started the car and the light had gone
but after covering the wire the light came on again!
Old 04-10-2008, 19:14   #9 (permalink)
MR.T
DRIFT RETARDED
MR.T's Avatar
is this random not reving past 2k revs what they call Limp mode?
Old 04-10-2008, 20:59   #10 (permalink)
MR.T
DRIFT RETARDED
MR.T's Avatar
right been out yet again and it cut out 3 times !! i'll explain again what happens as this time i had a better look, i pulled out a junction and just lost all power and go, the car was just idle ing and if i tried to rev it even foot to the floor! then it would rev from 1k rpm upto 1.4k rpm n drop straight back down to 1k rpm
i turned engine off for a couple of minutes then it was ok again
Old 04-10-2008, 21:02   #11 (permalink)
astra_coupe
having no luck
astra_coupe's Avatar
Send a message via MSN to astra_coupe
mines currently doing the same mate and my afm is more than likely dead... so your could either be a broken connection in the wiring or yours is going too... join my club
astra_coupe is offline   Reply With Quote
Old 04-10-2008, 21:05   #12 (permalink)
ady_mi16
have you sorterd this as my old s14 does this?
ady_mi16 is offline   Reply With Quote
Old 05-10-2008, 11:41   #13 (permalink)
MR.T
DRIFT RETARDED
MR.T's Avatar
still need help as this is also my work car!
Old 05-10-2008, 17:39   #14 (permalink)
MR.T
DRIFT RETARDED
MR.T's Avatar
bumps
Old 05-10-2008, 18:42   #15 (permalink)
astra_coupe
having no luck
have you checked for fault codes at all?
Old 05-10-2008, 19:18   #16 (permalink)
LiGhTnInG
Doricomotion
LiGhTnInG's Avatar
these connected?
Why don't you replace the cat sensor. Work back to when your car was in a working state.
Old 06-10-2008, 00:12   #17 (permalink)
MR.T
DRIFT RETARDED
MR.T's Avatar
yea matey i was thinking that but as the wire has come away from the sensor i think i'd need to replace the whole wire but it disappears under the car and dont know where it goes to
