just thought id ask if any one else has had any troubles/problems with there walbro fuel pumps? because this is the second time a walbro fuel pump has failed on me/broken!
i put one on my ae86, it was fine for a while then the car wouldnt start, traced the fault to the pump not working properley. i removed it from the 86. done some tests on it, and when hit with a soft hammer it would work. it had a loose contact inside sum where im guessing. so i needed a new one.
again fitted one to my r32gtst, due to the old nissan one braking. fitted fine with no trouble, has been ok till now!
when i stop and leave it idling, you cant hear the pump screaming, making this high-pitch noise, like its straining!? ive checked all the pipes to see that there not blocked, ive also changed the fuel filter and rubber fuel lines. the r32 will also get flat spots when driving, put my foot to the floor, nothing happens!? av to drop it down a gear! im 99% sure the engines getting no fuel!?
just getting f**ked off with fuel pumps, surley it cant be another faulty walbro fuel pump!?
any one else had any trouble with them?
r thats my rant over, feel alot better now lol, thanks for reading!
nick
LinkBack URL
About LinkBacks
, are check if im getting 12v to it then.
