Old 30-06-2009, 15:47   #41 (permalink)
Pro-tard
Captain Muppet's Avatar
Originally Posted by Vova View Post
If we look at his maths for a "standard car and tyre"
Standard car weight = 1500kg
Standard tyre width = 18.5cm
Standard tyre pressure = 30psi
Standard tyre pressure in Kg/cm^2 = 2.11Kg/cm^2
Weight on one tyre = 375kg
Contact patch = 177.7cm^2
length of flat at the bottom of the tyre = 9.6cm
Fair enough.
Now we let the air out...
Standard tyre pressure = 1psi
Standard tyre pressure in Kg/cm^2 = 0.07Kg/cm^2
Contact patch = 5331.7cm^2
length of flat at the bottom of the tyre = 288.2cm
Oh, that's a bit frigging huge isn't it? Tends towards infinity at zero pressure, if you're wondering why I used 1 psi instead of 0psi.
Now we fit the same flat tyre to, oh, I don't know, maybe an S1 Elise
Standard car weight = 750kg
Standard tyre pressure in Kg/cm^2 = 0.070Kg/cm^2
Weight on one tyre = 187.5kg
Contact patch = 2665.8cm^2
length of flat at the bottom of the tyre = 144.1cm
Now, I happen to know that with old Pirelli P Zeros and no pressure in the 185 front tyres an S1 Elise front tyre still doesn't go flat.
What does this tell us? His equation has no expression for the structure of the tyre, no sidewalls, no steel banding, no inch thick rubber with deformable blocks. All the bits which are carefully engineered in to a modern tyre. Great for getting his point across, but not the whole truth. An equation that asymptotes for flat tyres is one that doesn't reflect the real world.
You may think I being pedantic, but really I'm just a little bored and playing cut and paste in Excel while having a coffee I haven't a clue why fitting wider tyres doesn't increase grip, but at the same time seems to increase grip. It's all magic to me
Good excuse to wheel out the word "asymptote" though, which is one of my favourites.
__________________
BDC MX5
CaMouFlaGED-LeaRNiNg
Old 30-06-2009, 15:57   #42 (permalink)
MSAE
Keefe's Avatar
WOAH, whole heap of shit going on here.
Contact patch WILL change when using different size tyres.
From what i've heard, i'd listen to Captain Muppet on this one
And about 20%. But it's slip. Not grip.
__________________
Originally Posted by JDMgravy. View Post
You're too JDM tyte y0. You need to JDM chill-the-fuck-out
Keefe is offline   Reply With Quote
Old 30-06-2009, 16:02   #43 (permalink)
Pro-tard
Don't drag me in as some kind of authority...
__________________
BDC MX5
Old 30-06-2009, 16:03   #44 (permalink)
MSAE
Keefe's Avatar
HAHA i'm not. But when people question what you've said which is perfectly right, and then dispute it using information from TeH All KnOWin INderneTz then i'm likely to side with you.
__________________
Old 30-06-2009, 16:07   #45 (permalink)
Boro style
Mattyboi's Avatar
This thread is funny! And why engineers get paid alot of money and normal home mechanics build shit cars when they mod using stuff they read on the internet.
__________________
Old 30-06-2009, 20:01   #46 (permalink)
Send a message via MSN to steve.82
Originally Posted by Bladerider View Post
Touring cars are much better pointers to real world as they have not had the same restrictions.
I would go with hillclimb cars to give an example of what happens with less regs and without fashion dictated tyre sizes...
These are hillclimb specific tyres too, so aren't just hand me downs from highly regulated circuit formulae, so high sidewalls *can* be good.
Also they are huge, and barely have time to get warm. Skinny tyres would heat up much faster which would be good in a hillclimb car (standing start no tyre warmers allowed), but clearly wider tyres are grippier.
Originally Posted by royal View Post
Even with high pressures the wide tyres make the car much more snatchy and its easier to just use narrower ones
Narrow tyres with higher sidewalls can generally support a higher slip angle before break away.
Weight (well pressure) also has an effect on slip angle possible. The more weight on a tyre the sharper it can turn without breakaway, which is why race cars often have reverse ackerman. Which brings me on to...
'once the car lets go then you have no control whatsoever'
Most norms don't have much control, me included
But looking through some of the pictures here most of the time the front wheels are pointing the same way they would be during normal cornering. Does the Ackerman still work out ok on opposite lock? I guess it would work out to be effectively reverse Ackerman on a normal road car based upright?
Lambo and McLaren have 300 wide rear tires however only 225 front's, because the rear wheels heat up way more than the rolling, cornering and braking fronts. Than there are also the issues of resistance, scrub and many others but leaving those aside for a bit.
I disagree, I think it's largely because they're midengined and a bit tail heavy and powerful so need big tyres to get the power down (hot or cold!)
If you look at front engined RWD GT cars, front and rear wheels are relatively similar sized compared to their mid-engined equivalents.
Note: most of these comments are based on vague memories of lectures since when I've consumed too much beer and lost most of these memories... Liking this thread though
__________________
steve.82 is offline   Reply With Quote
Old 30-06-2009, 20:33   #47 (permalink)
S1- F.T break!
royal's Avatar
Originally Posted by steve.82 View Post
Narrow tyres with higher sidewalls can generally support a higher slip angle before break away. Weight (well pressure) also has an effect on slip angle possible. The more weight on a tyre the sharper it can turn without breakaway,
So with narrow tyres you have more weight on a specific area as per vova point? that make sense to me.
Its a long time point of conjecture on here. Some people reckon less ackerman like on autograss cars is good (Declan runs zero) whereas others such as Phil think its better to have it because the trailing wheel drags and helps to control the car in a slide. I suppose its down to driver preference and style? I'd like to try less ackerman just to see.
I didn't know people do reverse ackerman. I wonder how that would drift with the trailing wheel pointing in even more when on full opposite lock? I'd imagine it would make transitioning strange as the weight shifts from one wheel to the other and you have to change the wheel to the other lock?
__________________
Originally Posted by initial_j
you go in like a lunatic, nail it and let your hands/brain work out how to transfer it to the next corner.
royal is online now   Reply With Quote
Old 30-06-2009, 20:43   #48 (permalink)
I don't think reverse ackerman would be much use on a drifter really, as running normal ackerman geometry is effectively reversed when drifting, i.e. normally the inside wheel is actually outside on the corner, getting all the weight shift?
__________________
Old 30-06-2009, 20:44   #49 (permalink)
But then I guess it's not necessarily all about ultimate grip, more feel, in which case I have not a clue! haha
__________________
Old 30-06-2009, 21:26   #50 (permalink)
Vova's Avatar
Well doesn't more weight, contribute, to more heating of the tire...? Thus, what it all comes down to and is kinda my point?
__________________
S13: Turns ordinary men, into expert mechanics!
Vova is offline   Reply With Quote
Old 30-06-2009, 21:28   #51 (permalink)
Not when the tyres are cold no
__________________
Old 30-06-2009, 22:05   #52 (permalink)
Vova's Avatar
How do you mean 'when cold' ? Just rolling resistance of a heavier rear contributes to more heat, just as power transfer.
__________________
Old 30-06-2009, 22:06   #53 (permalink)
-NIGHTSPIRT FAMILY-
mitto's Avatar
ET made my dick get bigger...
think about it
__________________
- RUNNING FOREVER - STRAATGEWELD! -
mitto is offline   Reply With Quote
Old 30-06-2009, 22:43   #54 (permalink)
Vova's Avatar
Good article about Wider = more grip?
Browser Warning
__________________
Old 30-06-2009, 23:01   #55 (permalink)
I love mathematical models as much as the next chap, but I struggle to believe it. All this assumes mu is a constant, which I highly doubt that something as deformable as a tyre it is.
__________________
Old 30-06-2009, 23:03   #56 (permalink)
MSAE
Keefe's Avatar
Nothing to do with the deformability of the tyre. It's the surface it's rolling on. Models will normally quote an agreed figure for "decent paving" i.e. good tarmac.
__________________
Old 30-06-2009, 23:07   #57 (permalink)
Ok then, well as deformable as tyre rubber, I was a bit misleading with that.
Quick search on google...
The value of u is dimensionless when applied to sliding friction of hard surfaces. In situations where the surfaces deform or there is molecular adhesion, the friction is not independent of the areas in contact. In these cases surface area usually comes into play. This is also true for rolling and fluid friction. Although the standard friction equation still holds, the coefficient of friction may have area, shape and other factors included in it.
from forum chat I know, but clarifies what I was trying to say
edit: this was mentioned earlier by someone else too. So, ET's?
__________________
Old 30-06-2009, 23:14   #58 (permalink)
Another point... camber wouldn't matter (on cold tyres) if that theory was correct
__________________
Old 01-07-2009, 06:51   #59 (permalink)
shaiz's Avatar
Just had a quick skim through this. Someone mentioned that width doesn't affect the area of the contact patch, just the shape of it. If that was true (which I'm skeptical about but would need to lok into further) surely the analogy of rally cars using narrow tyres in snow to increase the force per unit area of the contact patch would go out the window. I'd get stuck into this further but I'm going to be late for work.
__________________
shaiz is offline   Reply With Quote
Old 01-07-2009, 10:14   #60 (permalink)
MSAE
Keefe's Avatar
Yeah it's bullshit. Of course it changes. That was just some internet fodder someone took as gospel as per usual. Which was wrong. As per usual.
__________________
Search this Thread:
Advanced Search
