Old 04-07-2009, 11:31   #1 (permalink)
199
Send a message via AIM to Phoenix Send a message via MSN to Phoenix
Nissan Skyline R32 Gtr Brake Calipers
Can anyone tell me if these are the lightweight ali calipers or the heavier cast calipers?
Looking at a set on ebay and don't want to buy them unless they're the lighter ones
Also are the rear calipers considered a decent upgrade when compared to the s13 rear calipers?
Many thanks
Forgot to mention the calipers are off a 1991 model
__________________
XBOX 360 Gamertag: PHOEN1XV8
Phoenix is offline   Reply With Quote
Old 04-07-2009, 12:02   #2 (permalink)
superclarkey's Avatar
that is what i have on my car, very good brake upgrade mate
Yes they are the lighter version.
Some people will claim they are the same as R33 GTST calipers but they are not.
Clarkey.
__________________
S-Body Steering Knuckles Modifications - PM me
HKS 2.2 500bhp+ 180sx Kouki Monster!
TEAM MINT
Old 04-07-2009, 12:11   #3 (permalink)
199
thanks for the info
__________________
Old 05-07-2009, 00:17   #4 (permalink)
talent bypass
SteveC200's Avatar
Clarkey.
Ditto on all that.
What master cylinder are you using Clarkey? I've got a modified S14 mc at the mo but have a Z32 to fit as I think the balance is a bit iffy.
__________________
Old 05-07-2009, 08:11   #5 (permalink)
Posh
They use wider discs than the R33 GTST ones for starters. Other than that they are pretty similar. Same pistons, seals, brake nipples, disc diameter, and basic construction.
Make sure you get the mounting bolts with them, they appear to be a different thread pitch to S14 ones. If you don't then you need 1.25 pitch bolts. RX7 ones fit with a washer to space them out slightly so you don't start winding in the shank of the bolt.
__________________
Originally Posted by Munky
It was like driving a trampoline, but looked badass.
Midlands_Si is offline   Reply With Quote
Old 05-07-2009, 08:30   #6 (permalink)
Yeah and you'll need a hose kit for them too..
Steve, I'm using the stock 180sx master cylinder, it works very well actually the car was ABS i never checked what size it is, but the brakes are very sensitive but i run the posh crossed drilled Factory R32 GTR discs with Mintex 1144 pads front and rear.
On the Federal tyres i've not been able to go fast enough to cause them a problem.. and i drive fast!!
__________________
TEAM MINT
Old 05-07-2009, 09:00   #7 (permalink)
199
cheers for the added info guys. The calipers are being bid on as we speak. The plan is to fit them to the s13/14 hubs and fit them to the Capri with uprated discs and braided hoses for some decent stopping power. As for brake booster and M/C, I dont have anything lined up yet but was looking at the Skyline setup once again. Like Clarkey, I'll be running Mintex pads
__________________
Old 05-07-2009, 09:05   #8 (permalink)
tcmotonut122's Avatar
i run those calipers with a r33 gtst mc and the braking power is really good, huge upgrade over standard, you with need the braided conversion lines tho.
tcmotonut122 is offline   Reply With Quote
Old 05-07-2009, 10:50   #9 (permalink)
199
When you say braided conversion lines, isn't it simply a case of getting the braided lines for the '91 Skyline GTR as that is the Brake booster and M/C setup I'll be using as well...or is there something I'm overlooking?
__________________
Search this Thread:
Advanced Search
