Old 04-07-2009, 15:23   #1 (permalink)
BDC Staff
lozza's Avatar
Send a message via MSN to lozza
Car stuttering at 2k ish
I'm not sure whether to worry about this or not as it comes and goes but the car (s14 standard engine apart from induction kit and exhaust) sometimes very badly stutters at around 2-3k which means theres practically no acceleration and it's hard to even pull away.
It's done it twice now, first time i had been driving it for about 5 minutes, it was a very hot day but i had only just stopped for traffic so it wasnt mega hot and it sounds like its running urm... burbly?? and drops to idle at 500 not 750.
Today it done it as soon as i started the car and went to pull away, it's not hot today but there is tonnes of rain, i managed to keep the car going for a little while and the problem seemed to go after about 5 minutes (so i guess when warm).
Any ideas?
__________________
Been 'flapping at the wheel' since summer 07
TEAM DRIFT BITCHES!
lozza is offline   Reply With Quote
Old 04-07-2009, 16:15   #2 (permalink)
ON A DRIVEWAY
skyludeboy's Avatar
Send a message via MSN to skyludeboy
screwed afm maybe?
__________________
FRONT YARD ENGINEERING
skyludeboy is offline   Reply With Quote
Old 04-07-2009, 16:20   #3 (permalink)
BDC Staff
lozza's Avatar
yeh thats being fiddled around with later on as my mate thought it could be that. any other ideas why it could be so intermittent?
__________________
TEAM DRIFT BITCHES!
Old 04-07-2009, 16:25   #4 (permalink)
Boost leak? Check all the hoses clamps etc and also the intercooler particularly if your still running the wing mount.
Tony200 is offline   Reply With Quote
Old 04-07-2009, 16:28   #5 (permalink)
BDC Staff
lozza's Avatar
I'll check all that too but surely that'd be a constant problem if it was boost.
__________________
TEAM DRIFT BITCHES!
Old 04-07-2009, 16:34   #6 (permalink)
Boost leaks can be temperamental especially if its a split hard pipe or something which only leaks on boost. The symptoms you describe definetly suggest boost leak (SXOC mode LOL).
Might be worth checking plugs/coils because if it sounds like a scooby at times it might not be firing on all cylinders.
Old 04-07-2009, 16:37   #7 (permalink)
BDC Staff
lozza's Avatar
It does this way off boost though, but i'll be sure to check all pipes etc anyway.
Will also whip the plugs out, cheers!
__________________
TEAM DRIFT BITCHES!
Old 04-07-2009, 17:43   #8 (permalink)
Joetastic
Joe-sef's Avatar
Send a message via MSN to Joe-sef
sounds like a boost leak, they can be random, hope its just that and a quick fix,...
__________________
Originally Posted by sideways.taff View Post
The Lion, The Witch and the.. mother fucking wall of death y0!!!!
Joe-sef is offline   Reply With Quote
Old 04-07-2009, 18:07   #9 (permalink)
FRANTIC
robbs's Avatar
sounds mostly like afm to me
__________________
Old 04-07-2009, 21:38   #10 (permalink)
-NIGHTSPIRT FAMILY-
mitto's Avatar
boost leak.
AFM.
plugs.
fuel filter.
coils.
fuel pump.
etc...
__________________
- RUNNING FOREVER - STRAATGEWELD! -
mitto is offline   Reply With Quote
Old 04-07-2009, 22:13   #11 (permalink)
adam0bmx0's Avatar
Send a message via MSN to adam0bmx0
Yea fuel pump could be on its way out.
Pull the AFM and give it a spray with some carb cleaner.
Check plugs, but money is on a boost leak.
__________________
adam0bmx0 is offline   Reply With Quote
Old 05-07-2009, 13:40   #12 (permalink)
BDC Staff
lozza's Avatar
Did that yesterday so it rules that out next time it happens/if it happens.
Will check boostage issue today thanks guys.
Is there any way of checking the fuel pump?
__________________
TEAM DRIFT BITCHES!
Old 05-07-2009, 15:13   #13 (permalink)
sorry to jack the thread lozza, i have a similar problem, but mines a stage one 91 s13, it runs normally, but so if i say it runs normally like this burr constantly, atm it runs burr . . pop burr . . popop . . burr it does this while just running. has new plugs at a distance of 0.8, has an exhaust leak at the end of the elbow to downpipe, its only just started doing it, if anyone can help would be appreciated!
chris_s13 is offline   Reply With Quote
Old 05-07-2009, 17:53   #14 (permalink)
sounds like the fuel pump on the way out,
what sort of mileage is on it?
Boss is offline   Reply With Quote
Old 05-07-2009, 21:04   #15 (permalink)
BDC Staff
lozza's Avatar
Well i've checked all the pipes to the intercooler and cleaned the AFM so hopefully it wont happen again but i wont really know as it wasn't an ongoing problem lol
Mileage is over 100k
__________________
TEAM DRIFT BITCHES!
Old 17-07-2009, 23:31   #16 (permalink)
BDC Staff
lozza's Avatar
buuuuuuuuump! it did it again. AFM has been cleaned out, to add to the info it also pops and bangs a lot more when it has this issue. So i'm fairly sure the AFM is fubared? but opinions please before i go buying. thanks.
__________________
TEAM DRIFT BITCHES!
Old 18-07-2009, 06:16   #17 (permalink)
talent bypass
SteveC200's Avatar
Have you run an ecu diagnostic?
__________________
SteveC200 is online now   Reply With Quote
Old 18-07-2009, 10:47   #18 (permalink)
.MTM.
egr valve?
Old 18-07-2009, 14:38   #19 (permalink)
S-bodied again
Andy_f's Avatar
If it does it after its been sitting idling for a while (like traffic) it could be plugs fouling.
__________________
Old 18-07-2009, 15:46   #20 (permalink)
BDC Staff
lozza's Avatar
Steve - i've not got the equipment but might know somebody who does.
Moose - whats that? Edit: i done my homework... where's that then? Edit: haha do i have to take the manifold off to get to it and what should i look for?
Andy - i'll be getting the plugs out tomorrow to have a look but i would have thought it would be happening more often if it was the plugs.
__________________
TEAM DRIFT BITCHES!
Search this Thread:
Advanced Search
