05-07-2009, 12:18
| tail slider Join Date: Mar 2009 Location: Hastings
| bmw m20 turbo conversion??
Was woundering if anyone on here new anything about turboing the old m20 12v engine? ![]() wat the limit's are? wats involved? cost? and wat would be a good size turbo? i was thinking an old cosworth turbo? any advise and tips cheers! |
05-07-2009, 20:04
| #3 (permalink) |
| spl dori master Join Date: Sep 2007 Location: Derby
Itīs a case of how much you want. They donīt bend rods and donīt blow pistons. Highest I know of on standard internals is 475whp. ARP headstuds depending on compression ratio (MLS gasket for 9.7, paper for 8.8 ) 55+ mm inducer turbo Donīt get a old turbo. Itīs pointless to try and build a crap setup. Youīll need a ecu, injectors, clutch, new "3 exhaust. massive intercooler. First though. How much power are you looking for?
__________________ Gunnar Reynisson No unauthorised trading or advertising. |
05-07-2009, 20:37
| #4 (permalink) |
right for starters mines a m20b20 they kinda hav a bad name but i like em lol ![]() was thinking of about 280-300 rwhp i want it to be quick and hav plenty of torque for drifting ![]() wat would be a good turbo for that kinda powerz? |
05-07-2009, 22:42
| #5 (permalink) |
Holset HX35 First of all I have a 2.5 without a head that you can get for 50pounds ![]() just get another head and your gold. I can give you intake manifold with the short block a 2.0 will be struggling for 300whp. 2.5 with stock head and cam will need about 1.2-1.3bar of boost on a HX35.
06-07-2009, 17:18
| #7 (permalink) |
Still going to need Clutch Turbo Turbo manifold wastegate intercooler plumbing injectors control mechanism for controlling fuel. downpipe exhaust Expect the same cost for 280-300hp as 400hp on a M50( cirka 3-5k depending on resourcefullness) Infact, add MLS gasket + ARP head studss and youīve got 500hp
06-07-2009, 21:38
| #9 (permalink) |
They last. May need stronger axles when you go sub 10sec 1/4mile. Nothing is bombproof, itīs all in the tuning and not overreaching the design. The problem is your RHD setups. It just hasnīt ever cought on making kits that fit RHD BMWīs. While there is plenty of LHD kitīs. Problem beeing that people usually go for bottom mounts , but that fouls the steering linkage on RHD cars.
10-07-2009, 01:01
| #10 (permalink) |
ok so holset hx35 ![]() that 2.5 block you hav a new head, inlet mani and exhaust mani. frount mount intercooler an ecu that can handle the new setup plenty of time and effort and a fair chunck of money ![]() im looking to save up some money and do it next year but can start collecting parts now |
