hello, I have some questions , some of them might be a bit stupid but oh well.. yes i did use search but not much comes up on soarer`s or the answers are not clear. they are terrible on angle, i have seen people drilling holes instead of cutting knuckles? which direction should i go cut or drill?? if drilling then maybe someone have any measurements where to drill the hole? if to cut then how big is the piece that i have to cut? again any measurements? Steering rack spacers 5.5mm or 6mm? what size spacer for clearance? any other easier angle mods? few 1jz questions, stock engine and stock turbos, aftermarket front mount, 3 inch exhaust, oil cooler, what psi can i run with greddy boost controller? 14psi max? how do ECU reacts to higher psi? can i slot in like chip in those ecu`s like on nissan`s ones? 1jz is non vvti , and it might sound a bit stupid but i cant see MAF anywhere? i did search and it comes up that vvti has one, but no maf on non vvti?
