Hello, I've got a question about the driftworks geomaster tie rods. I am wondering when i fit those on my R32 skyline GTST if they will not touch the Driftworks Nissan Tension Rods due to the extra lock in the tie rods or if it is necessary to also fit the driftworks geomaster tension rods
Hi there! The Geomaster version is designed to give extra wheel clearance when running wide wheels or large lock, you don't have to use the Geomaster tension rods with the Geomaster tie rod. It's just an alternate design, but for the £10 difference if may be worth future proofing yourself? Cheers!
True but i already have the normal tension rod version on my car and i am not willing to buy the other version if there is no actual need for it Thanks for your insights btw!
No problem! I just meant if you were deciding to buy one or the other (If you didnt already have either) Cheers!
