SR20-DET ignition conversion harness
Thread in 'Parts for sale' started by BOS WIRING, Mar 13, 2019.
  1. BOS WIRING
    BOS WIRING New Member
    Nissan Sr20-det ignition coil conversion harness + ignitor bypass adaptor.
    This harness is designed to fit S13, S14, S14A , S15
    Plug and play fitment. Complete with the ignitor bypass adaptor.
    This loom is made with raychem 55A spec wire. Heat shrink sleeving, flex guard oversleeving, standard rubber boots and adhesive transition.
    If you have any specific requirements for this loom please don't hesitate to ask. We are more than happy to build to your needs.
    All our harnesses are designed and built in England with over 20yrs experience in the wiring motorsport industry.
    Free postage and packaging is for UK customers only.
    Please contact us for worldwide postage costs.
    FOLLOW US ON INSTAGRAM ---- @boswiring
    IMG-20190313-WA0000.
    IMG-20190313-WA0001.
  2. BOS WIRING
    Sorry I forgot to add a price.
    We are charging £130 including post and packaging.
    We kept the earths independent to avoid creating ground loops. We grounded the signal wire to inlet manifold and the power to the body.
    Both grounds are labelled (ENG GND) (CHASSIS GND)
  3. driftaddict
    driftaddict Member
    Any looms for the 1jz to run with VAG coils ??
    Cheers
  4. BOS WIRING
    We have not made a loom for this engine.
    This is something we are interested in making.
    As it would be our first one we would need to do a mock up on your car. Or if your harness fits nicely as it is, we could borrow your harness as a reference to do a full mock up?
  5. BOS WIRING
    We are charging £125 including post and packaging.
  6. BOS WIRING
