BC Racing Coilovers for Chevrolet Aveo T250 06+
From £829.00 £690.83
Add to Wish List
Product Description
BC CoiloversSelect which products you need below, and click add to cart.
One BC Racing Series is available for this Vehicle:
The V1 Series Model is the perfect choice for street driving and the occasional road course or autocross duty. With easily accessible adjustment knobs for fine-tuning compression and rebound, ride height adjustment independent of shock stroke and spring preload.
See Description below for a more detailed description of the available series.
Many kits are available for same day dispatch (Mon-Fri), see listings below for expected lead times.
If you would like to check out the savings and upgrade to a set of HSD Coilovers click Here.
If you don't see what you're looking for just get in touch, we can supply the full range of BC products or suggest an alternative.
NOTE:All images are representative of the BC Coilover series and may not match those of the kit for your car!
The V1 Series Model is the perfect choice for street driving and the occasional road course or autocross duty. With easily accessible adjustment knobs for fine-tuning compression and rebound, ride height adjustment independent of shock stroke and spring preload, having a performance coilover system has never been easier. The driver chooses how low or high the vehicle sits (no preset ride height here!) and a BC Racing patented concave lower locking ring keeps it locked securely in place. Most systems can be upgraded to pillowball mounts to proved the most feedback possible from the suspension and to sharpen steering response. BC Racing front camber plates also allow a driver to get the perfect alignment setup without compromise. Each of these features is offered, while providing a strong, attractive coilover system at a reasonable price.
  • MONO-TUBE SHOCK DESIGN
  • LINEAR PISTON AND DAMPING CURVE
  • HEIGHT ADJUSTMENT VIA SHOCK BODY, NOT SPRING
  • 30-CLICKS OF DAMPING ADJUSTMENT (COMPRESSION/REBOUND) SIMULTANEOUSLY
  • FRONT CAMBER PLATES STANDARD ON APPLICABLE KITS
  • REAR CAMBER PLATES AVAILABLE ON APPLICABLE KITS
  • CUSTOM SPRING RATES AVAILABLE FOR MOST APPLICATIONS
  • CUSTOM VALVING AND/OR VALVING PAIRED FOR CUSTOM SPRING RATES
**Please note that not all vehicles use camber plates in the front and/or rear. Some vehicles reuse OEM upper mounts.
Reviews
Delivery Options
Enter your Country and postcode to check available shipping options for this product.
Finance Calculator
Questions & Answers
