Hello, i really fancy a change in car (MX5 RX7 supra 14a M3) but no one seems to offer close to the amount its worth so i wanna see if people would buy it in bits...If your interest in the whole car its here http://www.driftworks.com/forum/dri...s/111543-bdc-pro-spec-s13-testing-waters.html Basicly anything that i cant put in a box would need to be collected if i go through with it... Could people comment on if they feel the prices are right and if people would buy the majority of the items as its no good if the main bits go... Please e-mail as my PM box fills up quickly e-mail me at "alex -buckley@live.co.uk" Postcode is BS16 Engine Standard CA18DET engine. 112k. Always warmed up and cooled down properly, run on good oil and always kept at safe operating temperature. Runs and drives well, but will require a head change as it is currently filling the catch tank after around 10-15 long drifts at high revs and smokes a bit on overrun when cold. £100 T2871r 5000miles - £600 AVCR £150 Turbo braided oil line with fittings. £20 Braided water lines almost brand new. £50 DW catch tank with pipeing and bracket. £30 Walbro 255lph fuel pump. £50 Apex FMIC with pipework and fixings - damaged, but still perfectly usable. (The back side of it has a small hole punched in the end tank from a front end shunt. I've been using it with some metal putty plugging the hole all year, no probs) £75 Japspeed turbo elbow. £50 3 inch downpipe (flattened a bit on the bottom). £50 apexi catback. £70 Horsham Developments 'stage 3' chipped ECU. £70 Mocal 19 row oil cooler with thermostatic sandwich plate and braided lines. £90 EVO 510cc injectors. £50 Z32 airflow meter with plug. £100 Frenchweapon mild steel manifold. £200 Uprated engine mounts (pretty damn stiff). £50 DB power uprated rad - massive. Comes with an electric switch fitted for fans. £80 Transmission Welded diff (making noises). £20 Standard gearbox 80k. £20 Exedy tuff puck clutch. £150 Uprated gearbox mount (pretty damn stiff). £30 Cosmetics EPRacing bodywork: Genuine kouki bumper + spats £350 Doluck square indicators with sides and indicators built in £45 +30mm rear arches £100 Vertex style rear bumper large crack on corner £50 Origin style roof spoiler. £60 Msports genuine skirts (rare as rocking - light damage to the end of right side skirt. Would need a bit of glassing and filling to make perfect). £80 Advan SA3R 17x9 et25 5x114 with tyres - £275 Suspension/Brakes/Steering DW CS2 coilovers (1 seasons use. Mint) £480 DW full adjustable alignment kit (1 seasons use. Rubber boots cracked) £250 DW lower adjustable arms (1 seasons use) £275 Random Front strut brace £20 DW poly rear subframe £60 280mm 5x114 Grooved front discs £70 25mm bolt on spacers £60 S14 rear 5 stud hubs (can come with standard drilled discs to retain drum handbrake functionality) £50 Fancy front 5 stud hubs (can be fitted straight into standard hubs, meaning you don't need to change your lower arms) £120 Godspeed rear uprated ARB 1x droplink bent abit (im still using it) £100 Godspeed front droplinks £30 DW stainless collumn bush £10 DW poly rack bushes £20 Interior FIA Cobra Suzuka seat £200 (tight fit) OMP floor mounted seat rails £20 OMP WRC steering wheel in suede £75 Plumbed in fire extinguisher kit with all pipes and pullcords (pullcords might need replacing, 2010 expiration date so will need recharging) £40 Electric gauges - oil pressure (dodgy wire somewhere, is making a funny connection) oil temperature, water temperature, boost. All with wiring and senders. Will come with sandwich plate to fit. £100 Pivot tacho with control box, shift light and wiring £30 Fabricage 6 point bolt in straight legged dash dodger rollcage (no longer in production) with approved padding (at a cost of nearly £100) Really easy to fit, as you don't have to take the dash out. £350 Pictures of the car as it stands Thanks for looking Alex
i know but its not where my heart lies at the mo and its not happening yet unless people are willing Also can people no PM as the box filles up too quickly please e-mail me at "alex -buckley@live.co.uk"
I'd take the IC piping off you, bin the core as I'm swapping my sills for one on Sunday Possibly be interested in the braided turbo lines as well
i dont like posting things anyways but im not posting a fire extinguisher as it could be very dangerous
Please e-mail me at "alex -buckley@live.co.uk" DW 50 PM limit isnt enough to keep track of breaking a car
